A little but useful information for automatic transmission
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 20:14 # 1
emreteber
Hello friends.
I just bought my car, and due to the irregular shifts (high-speed gear shifts slightly knocked) that differ from my previous experience and low performance in traction, the solenoid change gearbox oil change software update style; While I am in the plans of how to get rid of this situation without taking the transmission in hand, I am free from my problems by fixing another issue that caught my attention.
Another point that caught my attention was that when I first started my car, the gear lock that did not react to the brake worked irregularly.
You know, when the gear is in p position, you press the brake and you release the lock. This was not mine, even when I started the car and did not move in a short time, the self-opening gear would lock and not open with the brake. I had to stop and start the engine again.
The trigger of this system, as you all know, is the brake sensor. When the brake pressed, my brake lights were on but there was such a situation in gear.
I bought a new brake sensor on Saturday and exchanged it, and I would like to point out that this tiny piece has gotten rid of all the problems I mentioned above with the change.
I had read somewhere that the problem with the brake not triggering the gear was the sender, but I did not know it caused this disorder. As such, I think that most people can handle this situation with the change of brake sender.
I wanted to share it because I thought it was useful information. I don't know if I opened the subject to the right place. If it's wrong, don't look at my fault. Wink
08.05.2020 20:14 # 2
Oktkor
Well, it was very useful. I did not use automatic gears even to try it in life, and when I pressed the brake I learned that the gear is locked or the lock is lifted.
08.05.2020 20:14 # 3
Thanks for the information, my teacher also causes irregularities in the gear changes.
08.05.2020 20:14 # 4
fkundak
https://youtu.be/z5g2zq_3xtc
08.05.2020 20:14 # 5
Htc
The gearbox has been revised, but the same problem continues, after 1 hour of driving, it detects the vehicle, and the speed is overnight at 4000.I will there be a benefit for me to change this sender.
brake sensor
08.05.2020 20:14 # 6
@Htc lady exactly that piece
08.05.2020 20:14 # 7
Htc
Thank you very much and I have an experience. Will it be compatible with automatic gear? I will ask you more Soner hocm the other day 10 thousand maintenance of mobile super 3000 5w30 oil was used, how this oil is not a problem. Do I take the filter and change it?
08.05.2020 20:14 # 8
brake sender compatible no problem. 5w / 30 oil is not suitable for your vehicle. Of course, a little oil reduction can be observed. you don't need to change the gasoline filter every time, I change it every 3 times. It is a local in 3 treatments because you do not use it constantly in gasoline.
08.05.2020 20:14 # 9
emreteber
[QUOTE = Oktkor] Well, it was very useful. I did not use automatic gears even to try it in life, and when I pressed the brake I learned that the gear is locked or the lock is lifted. [/ QUOTE]
How happy then me Smile
emreteb is 2017-03-07 20:46:26
08.05.2020 20:14 # 10
emreteber
Thank you friends. Trying will only cost you 25 TL.
