A light misfire 106 GTI
08.05.2020 14:54 # 1
TA3537
Friends, I will tell you a little bit, maybe it will be easy for you to solve.
My vehicle 106 GTI was not falling from idle 2000s recently, we cleaned the throat throttle idler engine etc. The problem was solved but there was a problem when the vehicle went from 2000 to 2500 rpm in the first gear and the speed in the compressor was falling when the gas was pulled down, the slightest misfire occurs in the 2000 1500s. in the second gear in your home. No problem if I give gas, no problem in the vehicle's departure, no problem in idling, but in traffic, for example, I went to the 1st gear, kicking it at the ages I said to transfer from gas. The vehicle is connected to the machine and there is no malfunction. Before this happened, the crank filter of the vehicle was old and oily. I would appreciate if you helped you happen, what is the source of the problem. Thanks
TA3537 2010-10-05 23:22:17
08.05.2020 14:54 # 2
voodoo
I think there is a weather problem .....
08.05.2020 14:54 # 3
TA3537
In the car, the software installed cycle is going to be quite a bit, I don't know how many over 8000
08.05.2020 14:54 # 4
TA3537
[QUOTE = Pug] Let me go slow in 1, shaking me, shaking me like this, shaking the same thing, doing the same thing with the 2nd gear, too slowly. I have a friend of mine, the problem caused by the gas pump is popping out. Like ladies gathered in a house day, hahah :) troubles are the same :) [/ QUOTE]
When I read on a subject from 2009, the same problem with this friend shakes when I do not gas in me until 2000 revolutions fall to idle. TA3537 2010-10-04 22:48:11
08.05.2020 14:54 # 5
TA3537
Does anyone know ..? :(
08.05.2020 14:54 # 6
alp34
Your vehicle's throat throttle, which you bought in the past, probably caused water or solvent mixed gasoline and air sulfation over time. You have performed this cleaning process by using a spray or removing the throat butterfly ... the tool is still working at high idle?
08.05.2020 14:54 # 7
TA3537
The vehicle does not have any problems in idle, as he said in his friend, msg dated 2009 but he does shake it
08.05.2020 14:54 # 8
TA3537
help ?
08.05.2020 14:54 # 9
TA3537
No one's only idea?
08.05.2020 14:54 # 10
Carmania
I think your problem is from the ignition coil, if it feels at low speed but not at high, I say 70% coil
08.05.2020 14:54 # 11
okankrgz
a relevant problem ..
08.05.2020 14:54 # 12
alp34
I cleaned that throat butterfly 3 times ... at the end, I changed the gas sensor cable to the throat butterfly. If there was a problem related to ignition, as the friend said, the vehicle always singles in the same way and the 4 cylinder vehicle operates 3 cylinders ...
08.05.2020 14:54 # 13
TA3537
[QUOTE = alp34] I cleaned that throat butterfly 3 times ... at the end I changed the gas sensor cable to the throat butterfly, if there was a problem related to ignition, as the friend said, the vehicle always singles in the same way and the 4 cylinder vehicle operates 3 cylinders ... [ / quote]
What can it be?
08.05.2020 14:54 # 14
this happened to me but the name of the cable I am replacing did not come to my mind ....
I'll write it to my mind.
08.05.2020 14:54 # 15
I did not think of it in life, so I took it to the master, could not find the problem ...
The man took me to an old master, he said, he found the problem ... I changed the spark plugs, I changed the spark plug cable, there was another piece that was important. I didn't think of him.
08.05.2020 14:54 # 16
TA3537
[QUOTE = facemelow A]
The man took me to an old master, he said, he found the problem ... I changed the spark plugs, I changed the spark plug cable, there was another piece that was important. I didn't think of him. [/ QUOTE]
What is this sister please remember this piece ...
08.05.2020 14:54 # 17
Carmania
Do not let the injections have an electrically covered rubber cable?
08.05.2020 14:54 # 18
TA3537
Uff Friend is not online I guess he can't remember the same fault and the part he changed ..
08.05.2020 14:54 # 19
I forgot the name of my brother, but all I know is that the spark plug cables that the spark plugs have changed and the spark plug cables have been interrupted in a small piece of the system.
I thought it was from the gas setting, when I did the same in gasoline, I understood that I went straight out of the spark plugs and the master was stopped ...
08.05.2020 14:54 # 20
TA3537
106 GTI mine is not LPG blah, but it is very mild this problem What is your vehicle?
