A Few Small Questions
08.05.2020 17:16 # 1
Resd
Hello Friends.
2004 Peugeot 307 XT I have and I am very very happy with my car. There are only two sound problems that I can think of.
1. While driving by car, the window is open, the left front wheel is coming out and sounds as if there is a stone in the wheel, but it is not stone.
2. Again, while driving, while passing through the light pits or something, a rustling sound is heard from the left side, and at the same time, sometimes the same sound is heard when doing firen. It sounds like it is coming from the steering wheel but the room is coming from the solteker if I'm not mistaken.
3. The steering wheel trembles when I brake at high speeds.
The source of these sounds and tremors seems like a single problem to me, but I'm not sure I haven't gone to the repair shop. I need comments from experienced friends. Thank you. Reviews
08.05.2020 17:16 # 2
soneroo
& nbsp; sounded like brake discs & nbsp; but excluding your 2nd question
08.05.2020 17:16 # 3
Serkan
If the sound is cut when the light brake touches while the sound comes out, it makes it from the brake pads.
2.?
3. It makes vibration from brake discs.
08.05.2020 17:16 # 4
Resd
[QUOTE = Serco05] 1. If the noise is cut when the light touches the brake while the sound comes out, it will be made from the brake pads.
2.?
then I have to concentrate on brake discs and pads.
2. Let me clarify my question a little more. Normally, the sound coming from the rods passing through the pits is a full sound. The sound in me is thinner and harder to hear, as if there is a slight gap and rubbing against each other, I liken it to the sound of a nylon bag.
08.05.2020 17:16 # 5
Serkan
If it looks like a creak, it can come from a swing.
08.05.2020 17:16 # 6
istanbullu_3886
[QUOTE = Resden] [QUOTE = Serco05] 1. If the noise is cut when the light touches the brake while the sound comes out, it will be made from the brake pads.
2.?
2. Let me clarify my question a little more. Normally, the sound coming from the rods passing through the pits is a full sound. The sound in me is thinner and harder to hear, as if there is a slight gap and rubbing against each other, I liken it to the sound of a plastic bag. feels like it rubbed into nylon bio
08.05.2020 17:16 # 7
istanbullu_3886
brake pads may have decreased discs must definitely be turned
