A few questions or questions about 307
08.05.2020 14:08 # 1
neo
Friends, I have a couple of questions about my 307 110 hp 1.6 diesel vehicle I received weekly press: & nbsp; & nbsp; & nbsp; & nbsp;
& nbsp;
1) When the rear of the vehicle is lying on the asphalt, when it descends fast from a bump or when it enters a pit on the asphalt, something asks in the trunk as if it comes back to the trunk & nbsp;
Do you have any kind of situation? why, what is the point of cutting the noise & nbsp;?
& nbsp;
2) & nbsp; there is a constant buzzing / whirring / whimpering sound even at low frequency while the vehicle is idling. When I went to the car and listened to it without opening the hood, I got an impression as if it were coming from a fan or engine. Does anyone know where this sound originated from, based on your experiences? & nbsp; & nbsp; & nbsp; & nbsp;
& nbsp;
& nbsp;
08.05.2020 14:08 # 2
individual
Take the 1-spare wheel and all spare wheel related equipment out of the trunk. Also, I don't know if they say a sponge, remove the fabric hard cover that covers the trunk (sometimes they put a column on top)
& nbsp;
try again like this. If there is no decrease in sound, equipment such as damper - wedge etc. should be changed. also prefer brands like monroe. Those of original peugeot production are a bit noisy. If you want to be original, choose the dampers in the XSI model. they run quieter than 5-door models and 3-door XS models, but are tougher.
& nbsp;
2- this is the sound of the steering pump. when you turn the steering wheel left and right, the sound will increase but it is a normal situation. sounds like moaning.
has nothing to do with this subject, but never turn the steering wheel to the right or to the left, do not hit hard.
08.05.2020 14:08 # 3
neo
[QUOTE = individual]
& nbsp;
2- this is the sound of the steering pump. when you turn the steering wheel left and right, the sound will increase but it is a normal situation. it sounds like a moaning. >
tskler for answers ... & nbsp; we have to live with this sound that I understand from the above, if it is, is it true? & nbsp; there is no way to cut it??
08.05.2020 14:08 # 4
taylor 307
& nbsp; I know that engine wedges cause a lot of these complaints in 307. wish you escape ..
08.05.2020 14:08 # 5
neo
what do you call the engine mount & nbsp; engine ears? & nbsp; the rumbling noise that I call alone ... & nbsp; & nbsp;
08.05.2020 14:08 # 6
taylor 307
yes engine support parts. These 307 engine vibration shakes or clicks are looked at first.
I use 307 too ... but I do not attach much to the sound event, because I think this 307 suspension event is chronic. I think the sound coming from the back is also from the springs.
08.05.2020 14:08 # 7
Tayfun
As far as I understand the chronic problem in the rear suspension sound pejo .. I have the same problem. I even took a friend's shock absorbers to the master as a result of his insistence, but there was no problem, said the master ..
08.05.2020 14:08 # 8
taylor 307
c4 is harder but in fact, my 1st month is over 307de..I worked, I cut the gas even if I eat the horn in every coffor :)
08.05.2020 14:08 # 9
neo
Although it is not very deep, I made it look. Pejo company in the spare tire in the back is thought to be fixed only in a completely empty way, without fixing it to the place, but only with the clamping tape on the top. he must have been playing and rumble in the spare tire once. I think the sponge is making clicks outside of it. but I think the back doors are another click source. rear shock absorber is produced in a very hard structure for some reason. I think it is for the purpose of handling ...
As a result, even though I haven't found the exact causes yet, sounds seem to be focused on these places in general.
08.05.2020 14:08 # 10
friends, I have x.yes, the backshocks are very hard.
08.05.2020 14:08 # 11
yigit1989
That sound was coming to me all the time, it was 20 days since I bought the car, I do not understand it, but if it sounded, you bought a new peugeot.
Do not worry as if there will always be a problem with your vehicle, but as you examine, the problem is emerging.
08.05.2020 14:08 # 12
hasimayaz
Although [QUOTE = neo] is not very deep, I made it look. Pejo company in the spare tire in the back is thought to be fixed only in a completely empty way, without fixing it to the place, but only with the clamping tape on the top. he must have been playing and rumble in the spare tire once. I think the sponge is making clicks outside of it. but I think the back doors are another click source. rear shock absorber is produced in a very hard structure for some reason. I think it is for the purpose of handling ...
Apply a sponge to the tire where it sits. The original sponge is deformed over time. New thicker sponge issue
08.05.2020 14:08 # 13
There is no spring-loaded shock absorber in the 307s, there is a spring-loaded shock absorber at the front and the arc is the spring-only spring-loaded shock absorber that prevents the vehicle from being overstretched in the velocity. it does not stick easily but it makes knocking feeling at low speed. It is like cotton when driving at 90 km speed. It is like a tractor at 40 km speed. Engine wedge is a chronic disease especially in dies in 307s. It starts shaking at the first starter and stop. I have friends who change in km, it will be more evident in winter.
08.05.2020 14:08 # 14
IBRAHIM
THE FRIENDS WERE KIRONIC THIS SOUND I LIKE A LITTLE MORE I HAVE BEEN OBSERVING THE LAST MONTH NIGHT, I HAVE REPLACED THE REAR SHOCK ABSORBERS AND TRAVERS CHOCKS, THEN I HAVE GOT THE VOICE, I HAVE SOME VOICES WHICH ARE REALLY GOOD.
AND I AGREE TO THE WHAT THE POLAT CAPTAIN IS SAYING
08.05.2020 14:08 # 15
when it reaches 200 kg of weight in the rear trunk or seat, it becomes like a Mercedes damper. beautiful
