A few questions about the 2004 Peugeout 307 1.4 HDI XR
08.05.2020 16:44 # 1
miraysoft
Hello friends, my car 2004 Peugeout 307 1.4 HDI XR,
Let's buy the car today it's been 25 days. In general, I am satisfied with the vehicle, but it seems to me that it burns a little too much. After putting 50 liters of diesel, 120 - 130 km, when the fuel is low, the light turns on and the vehicle starts to crow while running. Does it burn a lot or does it go more after the fuel light comes on?
Another issue, my car's original tape has been changed, and there is a pioneer tape. Therefore, the arm with functions such as the arm volume on / off station changing, which is connected to the tape under the wiper arm, does not work. Can this arm be integrated with another tape?
There is something we call a trip computer, and its lights are very dim. clock and temperature are flashing. Also, when the door is opened occasionally, it shows which door it is. Buddha & nbsp; it's pretty annoying. How can I make this man?
Something like a armrest is happening next to the driver's seat. It can be put into something for armrests and when the lid is opened. Can I have them installed?
I don't know much about cars :)
I would be very glad if you enlighten me. Best regards.
miraysoft 2012-04-29 15:56:55
08.05.2020 16:44 # 2
m1976k
first, good luck & nbsp; 1. the issue is no such fuel metering technique & nbsp; tool fullersin & nbsp; Birer biner is fullers again, the result of the fuller evacuates the discharge out of the diesel oil.
08.05.2020 16:44 # 3
muratoner
The dimmer of the screen is caused by the lighting bulbs behind it, i.e. it has exploded. If you press it on the front of the screen, you can disassemble it and there will be 2 bulbs.
& nbsp; & nbsp; When it comes to the fuel event, it varies according to usage, but if you use 1.4 hdi engine without compressing between 2000-3000 rpm in the city, it will burn around 22-23 cents.
& nbsp; When it comes to the tape event, every tape that is attached to these tools does not work from the remote control. If you need to search it, find the original tape and plug it in. If you want to sell it, I will ask you to sell it.
08.05.2020 16:44 # 4
alcolique
He needs to do something between 220-260 km with 50 pounds of diesel in the city. If it goes less than this, you either have a hardware problem or use it at high speed. & nbsp;
You can wear armrests. There are armrests produced by Armster brand for 307s.
If the on-board computer is dimmer day and night, there are problems with the LEDs behind it as friends say. But if it just gets dimmer when it's hot, the general problem of this 307 is for your knowledge.
Some pioneer and sony tapes work with that arm. The pioneer deh2300 I know should be working but more experienced friends will give a clearer answer than me.
alcolique 2012-04-30 09:35:51
08.05.2020 16:44 # 5
miraysoft
I extend my thanks to all the friends who responded.
alcolique, I think we are driving the same model, teacher. I made for the city in 40 km. Now the fuel light is on. I guess 150 160 would see it difficult. you mentioned 220-260 km. how is this possible? so what do I have to do.
thanks.
08.05.2020 16:44 # 6
alcolique
First start with the filters. When was the last time you changed the filters?
Then I say, look at the pipes that bring air to the engine. Burning rich mix increases fuel consumption.
Look at your oil. If the oil has lost its function, it will consume more fuel due to increased friction.
At what speed do you change gear? I change between 1800 and 2300. You need to pay attention to these. If there is one, remove the excess weight in your car, it affects the fuel consumption of the room. more. I have had 40 days or so, and I haven't been able to break records.
I hope I have been useful.
08.05.2020 16:44 # 7
hasiko
I have the original 206 cd player tape. compatible with the arm on the steering wheel. If you think I can sell it. interested friends can send a private message.
08.05.2020 16:44 # 8
miraysoft
I made the chipboard where there are 4 reports in the trunk.
and the wheels are 17 inches.
these increase fuel consumption I think?
I changed oil. I changed the oil filter.
let me replace the diesel filter, best teacher.
cycle 2500-3000 1. 2., 3000-4000 3.4.5. I'm doing gear. Otherwise (:
it is burning between 30-32 cents now. me too :) you are far ahead, thank you.
thank you for the comments.
08.05.2020 16:44 # 9
muratoner
My friend car 1.4 hdi 70 horsepower 17 wheels as far as I can see in the picture, the cheeks of the tires are 55 or 60, this is the biggest factor in fuel. The original rim has 15-inch 195.65.15 tires. My opinion is that the most rim to be fitted on the car is 16 inches 205.50.16.17 If you say you have bought it, you will benefit from reducing the tire's sidewalls to 45. & nbsp;
08.05.2020 16:44 # 10
alcolique
Exactly, the 17-inch rim will tire the already difficult engine. You will be loaded on more gas. Make the wheels of that vehicle 15 beautiful bidet engine maintenance, monster, you don't worry.
Thank you in the car.
08.05.2020 16:44 # 11
miraysoft
:) When I bought it, there was a rim and sound system, my teacher, I did not spend it.
I love my car. :) Reviews
08.05.2020 16:44 # 12
muratoner
Well, bro, if I were in your place, I would attach the original 5-spoke 16-inch rim of the 307. I would also wear tires on 205-55-16.
