A few questions about my car
08.05.2020 18:08 # 1
I have asked my mind for a few days. Can you help me?
1. My fuel nozzle is dropping too fast. It falls fast to see, but my road computer stays the same, and even knows in the back, does the car make extra stocks in the tank or somewhere in the diesel filter?
2. In the car, you put it in 1st gear and lift it off.
3. The display of the trip computer is mixed or darkened with the heat of the heater and the right side of it
4. When you go to the car while driving, it feels like a rubbing sound, but only when it is engaged while you are in gear, you shake the car idle. Could it be a hub ball?
5. The air filter bowl makes excessive noise as if the lid is open or there is no filter inside.
08.05.2020 18:08 # 2
kuscu38
I had the same 4th problem in you. I had trouble with the gearbox gears. My vehicle 306 rooms cost me 860 lira. :)
08.05.2020 18:08 # 3
I can answer the first. The correct proportion moves with the speed at which you make your trip computer. Don't expect it to show the same thing as the needle. If it shows 200 km while it is performing normally (such as 70 km), it can go up to 320 when you go with 30. On the contrary, your speed may decrease up to 130 when you reach 120.
08.05.2020 18:08 # 4
mami202
3, your question screen will be off the orange amber screens
I have the same problem with me, I think yours also has the same image on the right side, such as scattering of ink in a very small area.
mami202 2013-12-16 02:48:21
08.05.2020 18:08 # 5
[QUOTE = kuscu38] I had the same 4th problem in you. I had trouble with gearbox gears. My vehicle 306 rooms cost me 860 lira. :) [/ Quote]
No, it's not the gearbox. I'd understand it. Transmission continuous other.
08.05.2020 18:08 # 6
kursat3006
Porya ball, if no idle sound, try to understand where the sound comes from right or left
08.05.2020 18:08 # 7
[QUOTE = kursat3006] Porya ball, if there is no idle sound, try to understand where the sound is coming from right or left [/ QUOTE]
It comes from the right. However, I had a car that delivered the ball to the center before, such a sound was not making a worse and different sound. Her voice does not idle.
08.05.2020 18:08 # 8
bluefire
If you find a Led T5 bulb, the display of the trip computer comes alive. I finally got it yesterday. It was quite functional. He would go to the point of fading.
