A few questions about 206+
08.05.2020 14:17 # 1
I just joined your friends. For the first time, I use Peugeot. My previous vehicle was Ford Ford.
I want to ask a few questions now.
vehicle 2010 model 206+
When the contract is closed, the tape switches to saving mode after a while. The car does not open without starting. There is no solution to this.
2-In the user manual, follow me says it is available, I do what it says to be active. But it is not permanent. It is active only once. How can I do this permanently?
3-Is there a chance to activate the warning sound when the seat belt is not worn since I am not in a habit of wearing a seat belt? In the previous fiestam, this feature was not available, but I had read somewhere, and it was active when you did something like that.
Thank you so much questions for now ...
Birtan ÇÖTELİ 2010-06-30 00:14:27
08.05.2020 14:17 # 2
rifatseker
Hello Birtan,
Welcome with priority,
I have 206+ too old.
1. Approximately 15 min. then it goes into saving mode, you don't have the possibility to turn it off. But if you change your tape then it's fine.
2. After turning off the evening contact and headlamps for follow-me, if you only light up the highs once before leaving, the dipped headlamps will remain on for about 30 seconds and then turn off automatically. And you have to do this every time.
3. No seat belt warning, it will flash when turn on the ignition to start the vehicle first :)
08.05.2020 14:17 # 3
hakann308
[QUOTE = Birtan ÇÖTELİ] I just joined your friends. I use a peugeot for the first time. My previous vehicle was ford fiestay.
1-Saving mode is activated after 5 to 30 minutes depending on the power you use from the battery and no electronic equipment will work unless you start the car and compensate for the power you use.
2-There is no permanent solution. As your friend says, you will make a selector with the contact closed. 30 seconds. as short as it burns
3-Warning sound varies from model to model, some of them only have a light, while in others, this function is provided with a sweltering sound.
08.05.2020 14:17 # 4
I understand, thank you very much, I wish I wish you had been active spontaneously with the emminey warning lamp. :)
08.05.2020 14:17 # 5
BAHTIYAR
If you take the metal piece on the end of the seat belt and attach it to its seat, it will be silent on the market and it will be called a false seat belt.
08.05.2020 14:17 # 6
[QUOTE = 06BAHO] If you take the metal part at the end of the seat belt and put it in its slot, it will be silent on the market as a fake seat belt.
Thank you, but here I want to make a sound to wear a safety belt :)
08.05.2020 14:17 # 7
I wanted to revive the old position instead of opening a new subject.
1 - 2 years ago, the subject I asked still did not get me a satisfactory answer, it seems to me to activate the follow me event every time. Does anyone have detailed information about this topic, such as a continuous study after activating it once ???
2-When the car was unlocked accidentally with the remote control, it was locked by itself if no doors were opened for 45 seconds in my old vehicle. is there anything like that ?
because according to the service, there is no rds in these vehicles, there is no external temperature, but I had all of them fighting and fighting :)
3-There is no column in the back doors, there is no service cable organization. It makes a lot of cost. ? what makes it logical to wear a brand.
I'm thinking of a 4-american park. Can I assemble myself if I get the apparatus? (I can do this type of work) I looked at the headlights, the left side is not a problem, the right side is too narrow.
5-I have never used a car without a spring, but there is a system called rear torsion in this vehicle. I don't know much about the system. As far as I look at it, they call it a system that quickly fails.
thank you so much for now :)
08.05.2020 14:17 # 8
Alicilik
[QUOTE = Birtan ÇÖTELİ] I wanted to revive the old position instead of opening a new subject. 1 - 2 years ago, the subject I asked still did not get me a satisfactory answer, it seems to me to activate the follow me event every time. Does anyone have detailed information about this topic, such as a continuous study after activating it once ??? Such a feature is not even in 206 with night sensors. You can do this by attaching an additional piece. Developed parts are sold for this 2-when the car was unlocked accidentally with the remote control, it was locked by itself if no doors were opened for 45 seconds in my old vehicle. is there anything like that ? Because according to the service, there is no rds in these vehicles, there is no external temperature, but I had a fight and fight all of them. I examined the blowers that went to the back door. There are cables going to the back door. I don't think it will be another alternative. What brand would it make sense to wear? (Original tape without amps, I just want a column. The sound will be good enough. I pulled the line again and installed an amp-connected system. I think 4-american park. Can I assemble it if I take the apparatus? . You can make the socket directly on the socket without any hassle. 5-I have never used a car without a spring, but there was a system called rear torsion in this vehicle. I don't know much about the system. As far as I look, they call it a system that quickly fails. I think about 3.5mm. Does it make sense or does it cause problems? they are not. Leave the bow on the roads I use, even in this case, I travel hard. Of course there are those who use 5cm and are satisfied with 17 "wheels. Thank you so much for now.
08.05.2020 14:17 # 9
Thank you for your answers. Actually, I'm going to sell, never stop. Then I give up because it burns less each time :)
Let's come to the follow me event :) now he writes in the book. He tried it in everybody like me.
He said that when the doors are not opened, he leaves the door, why did he not get locked?
I never got into the spring + torsion job :) 15`` rim wouldn't look bad without a spring
In the sudden brakes, my 4 lamps are not lit, do yours burn? :)
Except for cruise control and road computer, I don't know what else can be done?
Birtan ÇÖTELİ 2012-09-14 01:30:36
08.05.2020 14:17 # 10
Alicilik
[QUOTE = Birtan ÇÖTELİ] thank you for your answers. I am actually throwing my head down, I never give up because it burns less each time :)
Follow me home is available in all vehicles. After stopping the vehicle, it is enough to make a selector once.
As I said, even my friend, who has a night sensor, makes selectors when he gets off, he becomes so active. Pejoda has such shortcomings.
The locking of the doors is also active, but as I said, it did not work. It seems to be a BSi-induced problem. There is certainly a solution, but we have to deal.
Torsion is up to you, but 15-16-17 doesn't matter, you can use a bow if the roads you drive are available. There is a noticeable drop in comfort. You will feel pits and bumps more. When you climb over 5cm, your front team problems start to increase. These are a matter of taste.
I work for a cruise. We seem to have reached the result, but you need a good service person pp200 and should use diagbox competently. Let's see, maybe a lot more nice features can be opened when setting up for cruise.
