A few problems about my 307 vehicle
08.05.2020 17:32 # 1
cnrars
Friends, I have a 2008 model 307 1.6 diesel vehicle, I have a few problems with my vehicle, I would be glad if the friends who have experienced them answer.
My first problem is about the digital air conditioner, the ac mode is active, and the strange noises are coming from the air conditioner, though in the normal mode, there are irregular noises from the air conditioner, which may be the reason. For example, I switch to the 23 degree auto / ac position, for a while weird sounds like flutter flick fiil, when I turn it off, the sounds that will make you say oh be.
My other problem is that when driving at a speed of 10-20 km, the vehicle does not notice in gear or empty, the hum comes from the left side, I think it comes from a place like rim, disc or pad, an increasing voice called vuuuu is cut off when accelerated. As if the disc or rim touched somewhere.
My other problem is that when the brakes are pressed (recently), the car is shaking close to the stop, meanwhile the car is pulling to the right, I think this is about tie rod or balance adjustment.
Why can these problems be mentioned?
Thanks.
08.05.2020 17:32 # 2
NightKiss
[QUOTE = 307bursa] there may be friction in the air conditioner fan
other problems, I think, may be worn or finished from pads and discs
I agree with a friend.
Flickering may be one of the disks with a skew. You can fix it by turning. If it is not very worn.
You probably got into cold water when it was hot. It is bent on the disc and bent over.
08.05.2020 17:32 # 3
cnrars
[QUOTE = NightKiss] [QUOTE = 307bursa] there may be friction in the air-conditioning fan.
Last week, I replaced the pads in the service, authorized service. He said that the pads will go for a while, but I changed it because he presses the brake, he said that the back pads were in good condition, they looked at the discs while removing the pads, your disks said well, meanwhile, when the brake pressed, it still sounds like viiiikk like a bird, so why?
08.05.2020 17:32 # 4
NightKiss
[QUOTE = cnrars] [QUOTE = NightKiss] [QUOTE = 307bursa] there may be friction in the air conditioner fan
Slowly step on the brake as you go. Measure the cut-off time. If it is doing too long, the disc will make a sound when it gets there.
Or it rubs the pad directly onto the disc. The brake center does not pull back completely.
You get the idea, if you want a consultation with the master after downloading.
08.05.2020 17:32 # 5
cnrars
[QUOTE = Nightkiss]
I tried what they said, when I touch the brake while going slowly, the sound is constantly coming, there is no decrease or interruption in the sound. When I do not apply the brakes, there is a roar that I guess is coming from the front, something is worth somewhere but I don't know what is where.
