A few problem ideas and help about 307? (dissolved
08.05.2020 19:17 # 1
Faruk
Hello friends.
My 2007 model 220 thousand vehicle has a few problems, I will take it to the service at the first opportunity, but I am curious about your opinions.
1- For the last one or two months, despite full flushing the tank, the needle was not sticking to the right, the last fulledim showed 1-2 teeth missing.
Is it a buoy or a reset or something?
2-My biggest problem is this stuck in my head.
For the past month, there was a roaring noise while accelerating at 1000 rpm in 3 gears.
Now he's doing that noise in every gear, except gear 1.
I think it could be engine ears.
3- I changed the compressor 2 years ago when I pressed the gas last year. My air conditioner does not blow cold after a sound called fısss this year in my first use.
Is it gas or is it a ruptor again?
I would like to thank my interested friends already
Faruk 2015-05-27 11:52:36
08.05.2020 19:17 # 2
brutal
Problem 1 - You definitely have a problem from the buoy
Problem 2 - Check the front flow seals and balls, and the transmission can be buzzing. The engine is not the ear, the problem is clear!
Problem 3 - I do not think it will be from the compressor, if the gas fulle 60TL try something again, if it does not give cold again, look at the air conditioner pipes, it may be drilled, rot and evacuate the gas.
If you collect all of the minor things, it will cost you 600-700 lira max.
08.05.2020 19:17 # 3
Faruk
Thank you teacher.
Since I pressed the gas last year, you probably have a problem with the pipes.
I changed the middle axle ball recently, but it was not the case.
Let me go to a service that will be evident in its solution.
08.05.2020 19:17 # 4
brutal
Especially if there is a rubbing sound on the right and left flow seals, a sound called vuvvv uvvvv results from it.
08.05.2020 19:17 # 5
Faruk
Thank you, sir. I will go to the service tomorrow morning.
I share the solutions from here.
08.05.2020 19:17 # 6
Faruk
I gave up making 1 buoy cost about 500.
2 air filters were said to have something out there, right now there is no problem in the car
Gas was pressed into 3 air conditioners, the compressor will be looked at again.
thanks to the interested friends.
