a few little questions
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508 (2019-)
19.11.2021 08:43 # 1
bumin12
hi guys, I just joined you guys and I have a few questions about the car :-)
1-) When I put the automatic transmission in manual mode and the gas is rooted, the automatic downshifts again. Is there a way to make it not do this? While my vehicle is in diesel and 7th gear, I suddenly find myself in 4th gear at high speed, as if it were a gasoline vehicle :-( because there is an unnecessary gear reduction for diesel, it is necessary to increase the reverse gear and this makes it meaningless to use it in manual mode.< br style="color: rgb102, 102, 102; font-family: tahoma; font-size: 14px; : rgb250, 250, 250;">
2-)Another question I have is that I turn off the start/stop feature every time (I don't think it helps much in the city except to spoil the battery in Istanbul), but it comes into play every time I park and restart the car. Can I turn it off automatically?
3-) I also change the driving mode to eco, the room returns to normal every time.
4-)my last question :-) when the windshield blower is turned on, the automatic air conditioner is activated and when the air conditioner is turned off, the glass blowing is also turned off :-) is it possible to blow the windshield with the air conditioner turned off?< br style="color: rgb102, 102, 102; font-family: tahoma; font-size: 14px; : rgb250, 250, 250;">
thanks
19.11.2021 09:53 # 2
hello sir
1- If you put it in sport mode and try it, it will shift more gear. However, when the bottom gas is in high gear, it downshifts due to the software and according to the speed situation in all these automatics. unfortunately you have to turn it off by yourself
3-I have no idea about it, frankly, maybe the tool doesn't accept eco mode because you are using aggressively LOL
Unfortunately, there is this in 4-digital air-conditioned vehicles, you have to turn off the air conditioner yourself and adjust it manually. I usually set both windows and feet in digital air-conditioned vehicles. It usually opens when the engine is cold.
19.11.2021 10:38 # 3
bumin12
thank you very much for the answers :-)
I switched from kia cerato diesel automatic to new 508 and kia did not have start/stop, other than that, I could do other items easily.
downshifting in manual mode is most challenging for me , I used to get to 7th gear on long road and drive without changing any gear , it was very good both in terms of performance and fuel consumption .
In terms of fuel consumption, it says 4.4 liters in the city and 3.4 liters outside the city:-) it burns 7.5 liters even though I have never been in heavy traffic :-) it is not possible to reach the booklet data I know, but usually in all my current cars, it used to burn 1-2 liters more, I can't get 70% of it :-)
can anyone get close to these values? I think that a vehicle of this size can burn these values, but only on a flat road without stopping and starting at a constant speed :-)
22.11.2021 20:06 # 4
anesteziugur
I have 508 diesel prime. I've done 10,000km in 5 months. I only use out of town. I always use the same way. My average extra-urban fuel when I drive aggressively: 7.1 lt/100 km, When I drive calmly (with about 120): 5.8 lt/100 km
The issue of gear shifting is a bit specific, I normally used eco mode, but I didn't notice that it changes when the vehicle is turned on and off. . But it is true that when it comes to extremes in manual mode, it shifts to automatic, that is, it switches to automatic. You are right about this.
24.11.2021 10:46 # 5
Even if there is no heavy traffic, the fuel consumption is high when used for a short distance, sir. what is the mileage of the car now
24.11.2021 11:15 # 6
bumin12
my car is at 32 thousand, its maintenance is complete. When I searched a little on the internet, I saw that figures such as 7-7.5 liters in the city and 5-5.5 liters for the city are more realistic, of course, as you said, distance, whether the road is flat or sloped, etc. environmental factors have a great impact.
07.01.2022 21:39 # 7
anesteziugur
1. I found the answer to your question: what you want to tell is downshifting or upshifting from the paddles behind the steering wheel. However, "It is necessary to press the M button on the gear lever"
I tried many times for you and forced the vehicle, in manual mode it does not downshift or increase unintentionally.
