A / C Malfunction
08.05.2020 16:52 # 1
Dostum
Hi Friends ... My car 307 HDI 1.6 digital air-conditioned ... I set the air conditioner at 23 degrees in hot weather, it starts to cool, it works about 4-5 minutes, but it stops blowing before it cools, sometimes 3-5 minutes later it tries to blow again, of course we We cook in the car until it waits for it to run again. I encounter the same problem when I run it manually and in automatic mode ... I wonder what the problem might be, can it be repaired with a simple intervention.
08.05.2020 16:52 # 2
fTh206
The air conditioner is automated, so it is the door according to the ambient temperature. Are you sure it is not automatically?
08.05.2020 16:52 # 3
berk2309
however, if you have a more common and large automatic air conditioner, there is a defect in the resistance of the card's cooling & nbsp;
08.05.2020 16:52 # 4
Dostum
[QUOTE = fTh206] The air conditioner is automatic so you are sure that it is not automatically according to the ambient temperature [/ QUOTE]
& nbsp;
no, it is not automatic either, I set it manually manually ... but after 2-3 minutes, the blowing is interrupted without giving birth ...
08.05.2020 16:52 # 5
Dostum
[QUOTE = berk2309] however, if you have a more common and large otomatic air conditioner, the cooling of the card has a defect in the resistance & nbsp; [/ QUOTE]
< / DIV>
& nbsp; & nbsp; What resistance do you have this picture & nbsp; and do you know how to check if it is defective?
08.05.2020 16:52 # 6
deme
[QUOTE = Dude] Hi Friends ... My car 307 HDI 1.6 digital air-conditioned ... I set the air conditioner at 23 degrees in hot weather, it starts to cool, it works about 4-5 minutes, but it stops blowing before it cools, sometimes 3-5 minutes later again we are trying to blow, of course we cook in the car until we wait for it to work again.I have the same problem when I run it manually and in automatic mode ... I wonder what the problem might be, can it be repaired with a simple intervention.
We are having the same problem 3 friends. Is it when you leave it in the sun. I'm doing an experiment like this, I put a cloth on the trip computer and protect that part from the sun. try it and share the developments thanks
08.05.2020 16:52 # 7
ibrahim YILDIZAK
I also showed that I have a little bit of the same problem, I did not make the fan motor thermal defective, I have not made it yet, I have a little trouble with the suspension, I write the results I will look at the air conditioner after I handle them.
08.05.2020 16:52 # 8
deme
I didn't solve the problem, friends
08.05.2020 16:52 # 9
Dostum
friends, we do not work with the air conditioner in the cold weather, after blowing the cold in the manual or automatic setting for a while in the hot air, the self-blowing is interrupted, I opened the bonnet and listened to the flap like the contact sound from the air conditioner compressor & nbsp; There are voices coming .... Also, I put the wet cloth on the trip computer and gave the same error again.
08.05.2020 16:52 # 10
Dostum
http://www.307online.com.ar/manuales/reparacion/ I searched for what is inside the small grille hole to the left of the front torpedo cover, on the right of the radio cd player and it is called "PASSENGER AIR TEMPERATURE SENSOR" from the link above. According to the angles, I removed it and then put it back in place after cleaning it with the spray, but after a while the air conditioner cooled, it stopped blowing again and gave the same error. How do we solve this problem ... : unplug the radio from the cd drive or box ISO (according to the specified technical value). Remove the internal temperature probe bracket (1) from the clip and bring it forward (A). Disconnect the connector (2). Remove the probe (3) and bracket (1) .2 - RE PLACEMENT Follow the reverse order of the removal steps. Check the operation of the electric device. Please.
08.05.2020 16:52 # 11
Celalll
Take a look at this link.
08.05.2020 16:52 # 12
monur
[QUOTE = don't say] I didn't fix the problem guys [/ QUOTE]
It happened but I solved it in manual type air conditioner.
I was turning on the air conditioner, it was blowing cold for 2 minutes, then the air conditioner stopped cooling when the engine was running. If your problem is doing this while the air conditioner compressor is running, the Expiration valve may be clogged (it turned out to me too). The reason for it is clogged is that there is a filter such as a black tube next to the A / C condenser, it is dispersed and clogged by the pin hole in this valve.
< div>
The master disassembled this valve, gave 100 g of gas when the pipes from high pressure were idle, cleaned the interior. ; "LOL"
90 TL Expiraton valve
120 TL filter
70 TL gas
50 TL workmanship.
20 TL pollen filter
< br>
In total, 350 TL of work has been solved and complete maintenance has been done.
08.05.2020 16:52 # 13
deme
[QUOTE = monur] [QUOTE = don't say] I didn't fix the problem guys [/ QUOTE]
I was turning on the air conditioner, it was blowing cold for 2 minutes, then the air conditioner stopped cooling when the engine was on. If your problem is doing this while the air conditioner compressor is running, the Expiration valve may be clogged (it turned out to me) There is a filter like black tube next to the A / C condenser because of its clogging. DIV>
The master disassembled this valve, gave 100 g of gas when the pipes from high pressure were idle, cleaned the inside, replaced the new valve and changed the filter, the air conditioner renewed the compressor oil and gased again, now the penguin has been fed into the vehicle & nbsp "LOL"
120 TL filter
70 TL gas
50 TL workmanship.
20 TL pollen filter
< BR>
A total of 350 TL of work has been solved and complete maintenance has been done.
my problem is the fan inside when the digital air conditioner is activated. riye & nbsp; stops blowing. I guess yours is different. I did a few operations, I hope I will try it today, it has improved
