A / C Malfunction
08.05.2020 17:49 # 1
06GSN77
Hello friends, I guess my air conditioner that worked without problems failed today, 3 of them are cold, but 1 of them is strangely hot as if it was turned on the opposite way. is such a malfunction possible, good forums.
08.05.2020 17:49 # 2
VLKNYKSLN
Did you clean the hood in fuel time or in 1-2 months?
08.05.2020 17:49 # 3
murateest
It is very unreasonable for such a thing to be technically.
Could one of the stages ever work?
Or may it be warm, not hot? (So at the outside air temperature level)
It is necessary to put the cold hot switch in the heat to come warm instead of cold, it is impossible to change this mechanical part without setting it.
08.05.2020 17:49 # 4
Does it mean the stages or the ventilation grills?
08.05.2020 17:49 # 5
06GSN77
Guys, I tried it again today, I think 2 of them have a problem. There is a warm weather. When I tried it the other day, it was very hot. I did not do anything vs maintenance, how much will it cost? 06GSN77 2013-07-27 16:42:48
08.05.2020 17:49 # 6
adil34
Hello,
I had a similar problem with my automatic LPG 307 vehicle. After installing LPG, 2 parts of the air conditioner came hot and cold from the others. I took it to the air conditioner, if you suddenly raised the degree and switched it from cold to hot, the curtain inside opened and closed during the process may have been broken, so only the hot side is open, but after a few days he said. & Nbsp;
The battery was exhausted because the headlights of the vehicle remained on the next day. I saw that the improved super works. This incident happened 8 months ago. & Nbsp;
It started to warm up again one month ago. Now I knew the method. I removed the battery terminal and plugged it in, the air conditioner came back to itself. I think it is likely to work.
It's hard to make sense, but after the LPG is plugged in, the brain of the 307s is getting mixed up well. / div>
After leaving the 1st bridge yesterday, the V-belt broke and damaged the engine, the vehicle is now in the service ... :(
have them checked on summer days. & nbsp;
08.05.2020 17:49 # 7
06GSN77
First of all, I will write what I said and try the result.
08.05.2020 17:49 # 8
murateest
Look, this lpg might be messing up.
Some of the lpg assemblies transferred to lpg and the motor water required for lpg may be problematic.
By the way, my fair teacher, have a great past.
It happened to me once, the timing stripping, but we saved it without damaging the engine.
08.05.2020 17:49 # 9
06GSN77
LPG is very good fuel but I cooled down
08.05.2020 17:49 # 10
murateest
[QUOTE = 06GSN77] LPG is very good fuel, but I cooled down [/ QUOTE]
I had my first car polo and my second car grand vitara and I used it a lot.
There may be minor problems, but I did not have a big problem. the water connection pipe was exploded on the road where t was connected. (authorized wv service) & nbsp;
I used it in Grand vitara for 1 year and had no problems.
08.05.2020 17:49 # 11
pusutr
I think it is useful to check the air conditioning gas.
08.05.2020 17:49 # 12
riva70
It happened to me two years ago. Both the honeycombs in the middle were blowing cold and the other one was blowing hot. air conditioner gas decreased, completed and improved.
