A / C Compressor
22.06.2020 16:21 # 1
properly1984
Hello friends, I have just joined you. I need to get information about Air Conditioning Compressor. I have a 2004 model diesel single door 206. When I went to the industry for air conditioning gas, it was said that the compressor is defective.
23.06.2020 16:50 # 2
Unfortunately, teacher, they are repairing it, the compressor is an expensive part. It is not known how healthy it is to go around zero 1200 TL. but it will be repaired between 300-500 TL, probably
21.07.2020 15:08 # 3
peugeot06
Air conditioning compressors do not get better with repair, they break down after a while, I recommend you take zero if you have power.
27.07.2020 18:59 # 4
properly1984
Friends, I went to a competent master, he took care of it for 15 minutes, the problem was not in the compressor, he said something as if the air conditioner was not working because the fan was not working. he received 150 money for everything, other masters had set a price between 1,500 - 2,000 lira. Unfortunately, sin should not be that easy to make money.
29.07.2020 04:21 # 5
aegeanxtr
[QUOTE = properly1984] Friends, I went to a competent master for 15 minutes. The problem was not in the compressor, he said something like the air conditioner was not working because the fan was not working. He took 150 money for everything, other masters had set a price between 1,500 - 2,000 lira, unfortunately, sin money should not be that easy. [/ QUOTE] My teacher changed the part in which fan? Air conditioning fan or radiator fan? I suffer from the same problem, the compressor does not turn on.
29.07.2020 09:15 # 6
get well soon with that, teacher. that part is located on the fan and when you look from the front, it is also on the left as a covered fan relay.
03.09.2020 10:32 # 7
properly1984
Sorry for giving me a late CVP, my holy man changed the material in the lower left corner of the big fan in front of the car, so they removed all of the front bumper etc, a green piece was oxidized over time, it was not activated, it changed the gas and the air conditioner worked.
03.09.2020 10:34 # 8
properly1984
[QUOTE = sonerkyl] get well with this, teacher. that part is located on the fan and when you look from the front, it is also on the left as a covered fan relay. [/ QUOTE] exactly where you say that piece :)
04.09.2020 00:05 # 9
aegeanxtr
I disassembled and cleaned that part and replaced it with a new one, but my compressor was still not activated. compressor tested with solid external power supply. But I have such a problem, the fan does not work on the first stage, it turns on when it comes to the second line after 90, it may be related to this problem.
