a-bag / s belts faulty
08.05.2020 16:44 # 1
true19
a-bag / s belts faulty emergency help 2006 307 sw friends have flashing on the road socket moket everything we have done 3 5 seconds lit flashing planet 2000 de air bag winding detected the master does anyone repair this winding emergency help: (( (the new one is pretty expensive
08.05.2020 16:44 # 2
true19
I think there is no one in this form or no one has come to terms
08.05.2020 16:44 # 3
Oktay Bey,
Our friends who are new members first introduce themselves under the information in the link below. I'll try to help you later.
http://forum.peugeotturkey.com/forum_posts.asp?TID=7516&title=new-years-cautious-contact-before- < br>
08.05.2020 16:44 # 4
true19
I didn't know this dating topic, now I wrote
08.05.2020 16:44 # 5
Have your car's airbags exploded before?
08.05.2020 16:44 # 6
true19
Yoo, I looked at the poles, bought the solid vehicle second hand, but the master said there was no accident. We connected to the planet 2000, the brain doesn't record as a malfunction as it flashes on the road, it looks like it was made out of the steering winding, but there was a new world money repair, but I couldn't find a master.
08.05.2020 16:44 # 7
true19
com2000 they call my electronic card in this steering coil
08.05.2020 16:44 # 8
true19
I guess it didn't happen to anyone com 2000 malfunction
08.05.2020 16:44 # 9
When do you get this error? For example, when you turn the steering wheel to the left while the error is on the screen, does the error disappear? Or is there any other situation like this? For example, when your headlights turn on?
08.05.2020 16:44 # 10
true19
Sometimes I get the error where I am, but generally when I am on the move, it gives the same error when turning left and right. I tried too much in the seat belt. pc is showing the error sometimes the lamp disappears even before the lamp is lit instantly so there was com com 2000 fault Brother
08.05.2020 16:44 # 11
[QUOTE = true19] sometimes I get the error where I am but generally on the move it gives the same error when turning left and right, I tried too much in the seat belt s belt maybe because it is a seat belt but the planet 2000 tied the master on the road while the airbag lamp was flashing while the pc was on the road, the device caught the steering light slightly to the right By turning it to the left, we tried it for a long time, even the pc shows the error sometimes the error disappears even before the lamp is lit instantly, so there was com com 2000 fault Brother [/ QUOTE]
Normally that winding is not easily broken. I think it must have seen a transaction from direksion or com 2000. Although it is thought that it is made of bandages, it is useful to try. First remove the battery terminal, then find the socket under the seat and remove it and put it back in nicely. Then place the pole head and try it.
When inserting and inserting the battery terminals, we will be healthy if we do according to the following rule:
http://forum.peugeotturkey.com/forum_posts.asp?TID=20338&title=aku-kutup-baslarini-sokerken-3 -minute-rule
koliva 2012-05-23 23:23:54
08.05.2020 16:44 # 12
true19
Brother I sprayed all the sockets with these sprays, even the master boy made minor corrections but the pole was removed without dismantling
08.05.2020 16:44 # 13
endorphine
It was like grasping the subject, but the same problem is in my car right now. Has any solution been found? My 2006 model 307 vehicle. Annoying malfunction. & Nbsp;
@ true19 wonder if you solved the problem? & Nbsp;
08.05.2020 16:44 # 14
mehmet_2
I also have the same fault airbag rolesi faulty 307 2006 hdi bitane bought bought, plugged in busefer esp lamp burned back in the old one, the lamp is still lit i am not shaking com 200 in my hand.
08.05.2020 16:44 # 15
Resd
The airbag light has been on since I bought Araby 4 months ago. I removed it, looked at the bandage, everything was intact and I put it on. It did not burn for about a month, then the backlight burned, and the new one is 350 400 TL. I found a price like clean price for a half price and everything is normal. Try a cleaning in Szler.
08.05.2020 16:44 # 16
Burak
It can be useful for other friends if people try to provide information.
08.05.2020 16:44 # 17
Serkan
I just received the same warning a little bit, the socket going under the seat to the seat belt loosened, I got a little tampered with it.
