99 model 206 gas pump electrical problem
08.05.2020 20:08 # 1
prdxy
Hello friends;
My vehicle did not work today, anyway, we looked at it as much as we looked, we researched and realized that there was no sound from the gas pump. Sequential system but direct lpg does not work lovato system.
Anyway, I opened it there, I was not tampered with sound, there was no sound coming from the pump.
Then I pulled the cable 20 seconds later, gasoline was over, it probably stopped when it was not pumped.
I do not know what number is the insurance in the table, I did not change the place of the woman, and it says time or something. Waiting for your support and suggestions before taking it to the master
good forums
08.05.2020 20:08 # 2
talip206
The fuse of the gas pump has blown. Depending on the model year and engine code, the insurance locations vary so it is not healthy to comment. Best of all, if the vehicle has a booklet, you can write it there or find the booklet online. Or you will disassemble it one by one and visually check it. I did so it didn't take ten minutes.
Lovato runs on lpg in the first run, but the system allows up to ten times.
To start with lpg at the first start, turn on the ignition and press the lpg button to start.
Insurance is 15amper number 2 in 2002 models talip206 2017-01-22 22:17:00
08.05.2020 20:08 # 3
prdxy
Unfortunately, I couldn't find the booklet on the internet.
08.05.2020 20:08 # 4
My teacher petrol role may be defective. control may also be required, not just related to the fuse.
http://www.peugeotmarket.com/peugeot-206-benzın-rolesı-orjınal,pr-566.html
08.05.2020 20:08 # 5
prdxy
I'm gonna have a look today
edit:
I left the industry to run with a cable and let's say good luck
prdxy 2017-01-23 11:23:50
08.05.2020 20:08 # 6
prdxy
Thanks to my friends who had problems with their cable, did not take charge :)
08.05.2020 20:08 # 7
ggitaristt
Get well soon Big smile
You officially lost your donkey and found it back LOL
