98 Mod. 306 Griffe stops with LPG.
08.05.2020 14:53 # 1
Bulent
Greetings, easy.
My vehicle is 98 Model 306 Griffe LPG
I have 2 problems with my vehicle;
1-When my car is in LPG and the air conditioner is turned on, it stops when I stop at the red light. They said the LPG idle is low, I raised the idle but the problem was not solved. I brought it to the service. They said there might be a problem in the LPG brain.
What is your opinion?
2-Sometimes the warning lamp with the K logo lights up on the indicators. What does this mean?
It has been 4 months since I bought my car, I do not know exactly, I would be glad if you help me.
Thanks in advance.
Good luck with
08.05.2020 14:53 # 2
The letter K is the engine fault light. On lpg vehicles, it firstly lights up due to mixture error. Of course, it can burn in another thing. also how did you raise your role ??? Or is there a venturi LPG system in its place?
08.05.2020 14:53 # 3
Bulent
Firstly, thank you for your reply.
My vehicle has a Mimgaz sequential system LPG. I have increased the working idle of LPG.
After the feast, I will bring it back to the service and ask both to stop and the K warning lamp.
Thanks..
08.05.2020 14:53 # 4
I have never heard of injection machines in the machine until now. The idle valve already sets this up according to the data from the brain. Can you explain how you did this ??? Also what is the engine? 1.6 or 1.8? also 1.8 se 8V or 16V?
Also, the idling becomes 1250 1300 only when it is cold and it is proportional to warming. Diffuse under 1000 cycles, such as 70C. when it is fully heated, it is necessary to run 800-850 cycles.
the cecol 2010-09-11 15:38:12
08.05.2020 14:53 # 5
Bulent
Thank you for your answer.
My vehicle has 98 Model 306 Griffe Mimgaz LPG sequential system tube. Vehicle 1.6 engine.
I do not understand engine and engine problems since it is my first vehicle. When my car was on LPG and the air conditioner was on, it stopped when it stopped at red light. (not always, sometimes)
I explained the situation to my uncle because of my work. My uncle got the LPG in the industry.
You gave me such a detailed answer that I was confused. What did this mechanic raise instead of idling?
Best regards
Good luck with
08.05.2020 14:53 # 6
bayelektronik
adjust and advance advance
08.05.2020 14:53 # 7
bayelektronik
I always see the same problems cecoli teacher, problems I try to explain
