98 406 ignition problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:58 # 1
McWarnaly
Friends, we went to buy this vehicle a few months ago, I tried to get the car for the first time even though it had not been started for a few months. He did not work.What we did was not.
08.05.2020 16:58 # 2
Serkan
If there is a problem in the immobilizer, the vehicle will start but it will not start, I guess you call the starter.
Edit: Location: Is it, where is it?
Serco05 < editDate> 2012-08-07 21:14:56
08.05.2020 16:58 # 3
McWarnaly
[QUOTE = Serco05] If there is a problem in the immobilizer, the car will start, but it will not start, I think the starter you call the starter.
Edit: Location: Is it? The location part was wrong. How can I solve this problem? The seller said that the reader on the contact needs to change.
08.05.2020 16:58 # 4
Serkan
teacher, there are two possibilities either the chip on the key does not send a signal or the reader on the vehicle does not receive a signal. it's best to have the service checked, & nbsp; at least 35-40 euros on the switch chip in Turkey, while Belgium's pretty good at 5-10 euro
08.05.2020 16:58 # 5
McWarnaly
[QUOTE = Serco05] my teacher has two possibilities either the chip on the key does not send a signal or the reader on the car does not receive a signal. it's best to have the service checked, & nbsp; at least 35-40 euros chip on the switch in Turkey and Belgium on 5-10 euro He was very good [/ QUOTE]
Valle vendor in the receiver in the car over there in agriz dedi.Bir 5-10 euros that the so inanmiyorum.ada Opt afraid our eyes probably But they came from the service and looked at the service, they said there was a problem with their computer. And at first, there was no problem. But it has been the same problem 3-4 times since then.
08.05.2020 16:58 # 6
Serkan
I don't think there is anything you can do, tell the service that has come and done before and tell them that the malfunction continues and check again.
08.05.2020 16:58 # 7
McWarnaly
[QUOTE = Serco05] I don't think there is anything you can do, tell the service that has come to the previous service and let them check again that the malfunction continues. [/ QUOTE]
Well, I don't know the service.You have to say: I bought the car from a car market in the Netherlands, when this problem came up, we brought a car from this dealer, he looked at the car, he said he didn't have a mechanical pain, he called another friend, he came and looked. We were not there at the moment. As a result, he will go to the service. Will I repair the car? Is it too high?
08.05.2020 16:58 # 8
Serkan
Get a price from the service first, if you get it on your head, maybe you have a simple cheap solution.
08.05.2020 16:58 # 9
McWarnaly
[QUOTE = Serco05] First, get a price from the service, if you sleep on your head, maybe you have a simple cheap solution. [/ QUOTE]
Thank you master. The car is not here now, we will look after the summer in our country goes to home.
08.05.2020 16:58 # 10
Wow from Belgium & nbsp; "Smile"
Is your diesel or petrol?
08.05.2020 16:58 # 11
McWarnaly
[QUOTE = koliva] Wow from Belgium & nbsp; "Smile"
gasoline 1.8
