98 106xr tape installation and advice
08.05.2020 19:27 # 1
ibanez_022
Hello friends,
My vehicle still has a fabrication confirmation. If I buy a new tape, does the socket structure fit or do I need to cut it? I do not have much budget, I will buy a tape recorder and 4 speakers, I am waiting for the advice of those who have done such transactions before 106
08.05.2020 19:27 # 2
samet206
If you find a suitable socket for the end of the tape's socket and design a suitable socket for the socket coming from the vehicle, then you do not need to cut and mow. As I said, if you do socket design, there is no other way than cutting and mowing.
08.05.2020 19:27 # 3
ibanez_022
[QUOTE = samet206] If you find a suitable socket at the end of the tape's socket at the end of the tape and design and make the cables coming from the tape outlets according to the relevant places of the socket from the vehicle, you will not need to cut and mow, even if the two-socket cable comes out of the tape box and fits the socket from the vehicle. As I said, if you do a socket design, if you can not do it, there is no other way than cutting and mowing.
Thank you for the answer, or if I actually want to get 30 TL and make it to the master of the work, I do not know if it goes to work but when I go to a master, I do not know if it is going to harm me.
08.05.2020 19:27 # 4
samet206
You're welcome, we all have problems, unfortunately, some of us careless behavior can bother the man, there are not necessarily such types. If the installation enters the withdrawal, the price will be folded. If it is to be made from 30 TL, I would say that there is no need to deal with these processes in myself.
08.05.2020 19:27 # 5
ibanez_022
[QUOTE = samet206] You're welcome. We all have the problem, unfortunately, the careless behavior of some of them can bother the man, they don't necessarily have to be. If the door trims are removed and the cable harness is pulled, the price will be folded. If there is to be done from 30 TL, I would say that you do not have the realm of dealing with it in myself.
There is no need for door upholstery, you already know, it is enough to remove the pockets below, and the speaker installations are ready at the front and behind, I know the assembly price is around 30 TL. Yes, I can count my hand, I changed the gas pump at one time. I replaced it with a new one :)
Let me see according to the situation :) What would you recommend tape
08.05.2020 19:27 # 6
samet206
Yes, 106 is not enough to disassemble the pockets, it is not like 206 for the speaker connection.
Examine the location, it is definitely useful for your business. I have shared my work before.
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=40027&title=sony-dsxa35u-teyp-soketi-hakkindamontaj-yapil
samet206 2015-09-23 18:39:20
