90 km speed at 3,000 rpm 5 gears
08.05.2020 19:31 # 1
alihan59
Why is my 90 km speed and 5 gears not less in 3,000 rpm, why is my vehicle features 1,4 xt 2000 model? And they pull the amp cable from this left door to the trunk or they have ruined the door trim.
08.05.2020 19:31 # 2
talip206
There is an abnormality if the road is flat, it is around 110 at 3000 rpm, mine is an automatic 4-speed vehicle. There are a few possibilities, your indicator may be defective and maintenance may be required. When the spark plug air filter changed or something.
The plastic clips of the door trim are broken and do not hold it. You can buy new ones from 3 to 5 liras. talip206 2015-11-29 22:28:41
08.05.2020 19:31 # 3
alihan59
I don't know when the spark plug air filter has changed. I have no information. I have been in it for 3 months. I have made 2,500 km.
08.05.2020 19:31 # 4
Barut
There may be a problem with the press pad, I think.
08.05.2020 19:31 # 5
KILIC
my 1.2 corsa also shows 90 at 3 thousand revolutions. I think it's normal, my automatic 307 showed 110 at 3 thousand revolutions but it is 1.6 110 hp.
08.05.2020 19:31 # 6
yangsagan
I am speeding 110km at 3000rpm in 5 gears. 1.4 gasoline 206.
The same speed must be reached on the same vehicles.
The speed reached in different vehicles does not indicate that the vehicle is stronger / weaker. This is about both power and gear gear ratios.
Sample.
Although the 1.4 hyundai accet era is 97hp, 100km / h at 3000rpm
1.4 peugeot 206 75hp. 3000 rpm doing 110 km / h.
08.05.2020 19:31 # 7
Gokcesel
I tested it on the request of a friend 2 days ago in 5th gear , it goes with 135 in 3 thousand revolutions . Vehicle 2004 model 206 1.4 hdi
08.05.2020 19:31 # 8
ismailkaya
Since it is 75 hp, the vehicle shows 90 at 3000 revolutions.
08.05.2020 19:31 # 9
muhammed.ceyhan
My vehicle is 2000 model 1.4 xr. lpg li. I make 110 km at 3000 rpm.
08.05.2020 19:31 # 10
2007 1.4 8V fever
08.05.2020 19:31 # 11
alihan59
Can I change the pressure from my battalion, they gave him 550 TL, there is no money, I can't change it, but the same model has another 206, it goes as fast as 90 km.
08.05.2020 19:31 # 12
talip206
It does because of the printing pad. Normally mine does 110 too
