8v 16v?
08.05.2020 18:46 # 1
jembey
2005 & nbsp; model x-line I have 206 auto tools, 8v or 16v, where can I understand, and what are the pros and cons, also I don't find the central key, I manually close it I went a little strange from inside, I don't have a bidet immobilizer, I think there's no red light flashing inside. THANKS.
08.05.2020 18:46 # 2
Alicilik
Hello my teacher,
Welcome. With Ankrada pejo, I can help you with most of the things that get on your head.
If you send a private message to the vehicle's chassis number, let me extract all the information.
08.05.2020 18:46 # 3
halit54
The top engine is 8 valve. 16valve model below. The engine with 16 valve does not search for diesel with careful use :) The 8-valve is insatiable. (Subject to use without LPG)
08.05.2020 18:46 # 4
Mbiwa
I have 8 valves lilk motor, my motor burns less than motorbike. Those who say 8valf e burned did not use.
I do not know if I will burn less than 16, but I have not tried less than 8 valves.
08.05.2020 18:46 # 5
samet206
Metal cover motor 8V Plastic cover motor 16V is generally like this ...
08.05.2020 18:46 # 6
halit54
[QUOTE = Mbiwa] I have 8 valves lilk motor, my motor burns less than the bike. I did not use the ones who say "8 valve is very good."
my brother, my brother has 2005 206 xt 16v. It burns around 5-6 liters in 100 km. seeing 4.5 on the long road. Likewise, my sister had 8v 2008 206 sedans. The urbanist who burns 9-10 liters. Both of the vehicles are around 70-80 thousand km, the original lpg is not installed.
08.05.2020 18:46 # 7
sahbaz24
8 valves love gasoline very much =) 16v is more accurate.
08.05.2020 18:46 # 8
Mbiwa
[QUOTE = halit54] [QUOTE = Mbiwa] I have 8 valves lilk motor, my motor burns less than motorbike. I did not use the ones who say "8 valve is very good."
I forgot to write a vehicle with lpg. & nbsp;
08.05.2020 18:46 # 9
jembey
As far as I understand from the pictures, my car is 8v. Thank you very much for your interest.
08.05.2020 18:46 # 10
fætih
[QUOTE = halit54] [QUOTE = Mbiwa] I have 8 valves lilk motor, my motor burns less than motorbike. Those who say 8valf e burned did not use.
teacher, my brother has 2005 206 xt 16v. It burns around 5-6 liters in 100 km. seeing 4.5 on the long road. Likewise, my sister had 8v 2008 206 sedans. The urbanist who burns 9-10 liters. Both of the vehicles are around 70-80 thousand km, lpg is not original.
If there are 1.6 vehicles burning 6 liters of gas, direct me.
1.6 16 v 206 minimum 7.5. lt burns the room in the city, an optimistic figure ...
08.05.2020 18:46 # 11
ahmed206
Excerpt from the hardware news:
between 8v and 16v The difference is decisive in the torque and power outputs of the vehicle's engine. A vehicle with 8v gives the power it generates compared to the 16, for example, 100 hp at lower revs. Especially the torque is effective at lower revs. For example, the vehicle with 100 hp at 3000 dd, but 16v gives 100 hp at 5000 and over. torque is also effective in medium revs. & nbsp;
8v vehicles consume less fuel than 16 v vehicles. But in the long term, the superiority of 16 v vehicles is indisputable. 16 v is always superior in long road or general use. 8v vehicle has one valve per cylinder and 2 in 16v. this enables the combustion and power produced by the engine to be more balanced and effective. The engine of the 16v vehicle runs quieter and quieter.
Reviews
Reviews
