88 thousand maintenance and others kept 1030 TL ....
08.05.2020 14:54 # 1
Faruk
Today I took 307 to 88 thousand maintenance from the morning.
it cost 1030 TL including the total vat ... but we were able to reduce it to 850 with a little bargaining, but the price was our first expense, but since we received it, I would say that God will not cause any trouble, but when we got out of the maintenance, we had a small accident in the bidet.
What should we say good luck and let him come to the property?
Uploaded with ImageShack.us
08.05.2020 14:54 # 2
Faruk
I shared it to the people who will take care to get an idea on the price consultation.
the price of most parts here ...
08.05.2020 14:54 # 3
Faruk
disk, tie rod, tie rod head and brake center change twisted our waist, already they hold around 400 TL as a part, bidet would have fallen in labor if they did not change 450-500 TL unexpected expenses.
08.05.2020 14:54 # 4
headlight bulb 5 tl
oil filter 8 tl
air filter 10 tl
pollen 15
diesel oil 35
engine oil 35 tl
no need for glass water and is very expensive.
I think the peugeot authorized service is this incredibly small money so I quit going to the service, good luck use it
08.05.2020 14:54 # 5
First of all, use it well. be in the accident
It was the brake center that caught my attention. Whether the brake center is deteriorating at 88.000 km. It seemed so crazy to me. Is there a problem with the brake? weakness or hydro hijacking etc.?
Let's say, if there is a defect, the repair kit usually changes ... many of them have not been written to the list, which is not centrally written. Were they freaking acep ??? :))
the cecol 2010-10-07 16:12:12
08.05.2020 14:54 # 6
Faruk
[QUOTE = cecoli] Use it good bye first. be in the accident
If I don't remember it, don't come out. He has provided the others so that he will not pass much.
I did not understand or understand in the case of braking.
They said it has to be tightened.
08.05.2020 14:54 # 7
Faruk
[QUOTE = EmRaH] headlight bulb 5 tl
oil filter 8 tl
air filter 10 tl
pollen 15
diesel oil 35
engine oil 35 tl
special service but the price is noticeable but according to the place, but they did not matter, the rot brake was blah or something, which is the money that holds the money ... it took more than that face in workmanship. Whether construction, nothing else will happen .. if the oil and water filter change after the next ii ..
They said 120 thousand to the triad, we are comfortable in terms of money for 1-2 years from God ..
08.05.2020 14:54 # 8
the first time I heard the break out of the brake center ... also the hıdrolık event no pıyasada ??? When replacing the brake center, hydraulic flows and they need to put new hydraulic on it. Wouldn't it put the hydraulics that put the lining spray on the bill? Or did you say that we changed it for you, what is it piled for you? Of course, this is just an idea. I do not want to give any bad accusation to anyone or anyone ... did they give you the old one?
08.05.2020 14:54 # 9
Faruk
[QUOTE = cecol of]
There is no possibility of doing such a thing, there are very old customers and relatives who are remembered, but we do not take the part in everything for 10 years, so we know that we are tired of throwing it in the trash at first, they know that we do not want it for her ... they may have come out as something, etc. etc.
2, since the month, they said that the debt to the small faults and the parts are what we owe to the question. .this is the fineness of the work but i dont wear it on my head, our trust is exactly in everything ...
08.05.2020 14:54 # 10
bulent 77
balata spray 2 pieces very enterasan.bizım master can't finish 1 :)
08.05.2020 14:54 # 11
Carmania
They wrote the lining of the lining of the lining of the lining. If you did not open the engine from god, they would also add the torque wrench to the invoice.
08.05.2020 14:54 # 12
volkan_uysal
Timing set unchanged?
08.05.2020 14:54 # 13
BAHTIYAR
As the cecoli brain says, the change of the brake center is very interesting in my taunus when the vehicle was at 200 thousand, they did not write hydraulic 5 lira maybe
08.05.2020 14:54 # 14
BAHTIYAR
By the way, I changed the timing set + mobil one 10 60 engine oil (100tl) to 420 lira. or 80 thousand km, I changed it for years
08.05.2020 14:54 # 15
Faruk
[QUOTE = Carmania] They wrote the lining of the lining of the lining of the invoice. If you did not open the engine from God, they would also add the torque wrench to the bill :) They should not call you and write the parking money or something for your problem.) [/ QUOTE]
08.05.2020 14:54 # 16
Faruk
[QUOTE = 06BAHO] by the way, I changed the timing set + mobil one 10 60 engine oil (100tl) to 420 lira, so if I do not count the oil, I changed your triange 320 lira to 70 thousand in the complete set, there was no wear on the triger, there were cracks in the alternator belt, diesel gasoline noticed. I don't know if it is 5 years or 80 thousand km, I changed it for years [/ QUOTE]
I insisted that it change in the triyer, he said to the master but he said at 120 thousand and did not say anything else, if it changed in the triyer, we would sink well :))
