85 degree fan opening
08.05.2020 21:07 # 1
Xpower
Hello, 206 1.4 8 valve 2005 model gasoline 85 degrees fan opening is normal? Is bottom gas at 80-85 degrees a problem? and would it also be a harm if we change the short-type engine oil filter and cap to the long-type? Xpower 2019-01-15 20:02:02
08.05.2020 21:07 # 2
GokhaN
Hi
85-90 degree fan is normal. Why is it short if you change your original?
08.05.2020 21:07 # 3
deneme51
I have never heard of a pejo that opens a fan at 85, I personally may have changed the thermostat in the original, but the panels open the fan at 97
08.05.2020 21:07 # 4
Levent206xt
The first stage opens the fan at 97 and the second stage opens at 106.
08.05.2020 21:07 # 5
Xpower
[QUOTE = trial51] I have never heard of the pejo that turns on the fan at 85 I personally might have changed the thermostat in the original but the panels open the fan at 97 [/ QUOTE]
Ours is opening Smile
08.05.2020 21:07 # 6
Karacocuk24
Well, it hurts at 90, mine can pass 100, then it descends again, it rises again, I love my car very much, except for the temperature indicator
