5w40 - 10w40
08.05.2020 17:46 # 1
erdinho
What is the difference between my car, diesel 207 and 5w40 - 10w40 oil which I will change the oil and which brand should I use and your brand suggestions? I am confused
08.05.2020 17:46 # 2
ErolSs
5 40 petrol, especially lpg li car oil I know
I think the difference between the thickness or thinness
08.05.2020 17:46 # 3
erdinho
Isn't there any friend who is experienced or understands this subject?
08.05.2020 17:46 # 4
mistik
one is semi-synthetic and the other is fully synthetic. If the mileage of the vehicle exceeds 90 100 thousand, you should use 10/40, I think, a thicker oil than the other wraps the tiny spaces in the engine due to the mileage, reduces friction. 5/40 is fully synthetic, provides a little more performance, gives less sound, if your kilometer is less, you can use 5/40, you wouldn't mind.
08.05.2020 17:46 # 5
mistik
[QUOTE = ErolSs] 5 40 petrol, especially lpg li car oil I know
[/ QUOTE] There are also ones for 5/40 diesel .. in well-known brands .. generally, as your friend says, there are also for gasoline .. when buying it, be careful that it writes petrol or diesel.
08.05.2020 17:46 # 6
When the headlight oil is cold, the viscosity of one is 5 and the other 10. Use whichever engine oil number is recommended for your vehicle. Please give the model, engine information, if you want.
08.05.2020 17:46 # 7
GokhaN
If the vehicle's engine is THP, I recommend 5w30 HDi, 5w40 normal gasoline and 10w40.
08.05.2020 17:46 # 8
megez
My car is 1.4hdi I change oil every year, I use 5w40 synthetic oil. The sound of the engine is positive.
