5cm spring, inspection
08.05.2020 16:41 # 1
svgkhn
hello friends
I will have a question. div> & nbsp;
can I get information.
koliva 2012-04-05 22:50:37
08.05.2020 16:41 # 2
Barut
I know that it will not pass because they did not spend 2 months ago in my car because they have 3.5 bows.
08.05.2020 16:41 # 3
omer_tarsus
Take it to the inspection without having your car do anything, and get there if there is a problem. As a worst case, even if there is a serious defect, you will have it done after 1 month, and it will go forward on the date of examination.
08.05.2020 16:41 # 4
senol73
[QUOTE = ömer_tarsus] Take your car to the inspection without doing anything, if there is a problem, get out there. As a worst case, even if there is a serious defect, you will have it done after 1 month, and it will go forward on the date of examination. [/ QUOTE]
+ 1 & nbsp; "Wink"
08.05.2020 16:41 # 5
herry
As the friend said, if you go with the usual form of a problem, you can see according to the situation.
08.05.2020 16:41 # 6
ozaannn
I promise as a guarantee I went with 5 cm bow and 16 rims at once, only the headlight alignment will be faulty room, I'm sure you can trust it
08.05.2020 16:41 # 7
okan4037
You generally pass through the bow, you pass the folks, if you do not come to life :)
