5 minutes after locking the vehicle
12.06.2020 01:07 # 1
Kaiken
Hello friends, I just bought my 206+ vehicle and I am facing a problem. I can open the vehicle manually when I open it, but when I want to open the vehicle from the remote 5 minutes after leaving the vehicle and locking it from the remote control, it does not open what should I do
12.06.2020 12:27 # 2
talip206
First, replace the battery. There may be similar situations when the battery is almost empty.
12.06.2020 13:37 # 3
Kaiken
[QUOTE = talip206] First, replace the battery. There may be similar situations when the battery is almost empty. [/ QUOTE] I replaced the battery but there was no change
12.06.2020 17:24 # 4
I say make the switch off switch switch on the switch can be broken, my teacher.
13.06.2020 01:30 # 5
talip206
A strange malfunction. When the vehicle stops, it switches to eco mode after 4 5 minutes. If the installation has been tampered with, they may have pulled the electricity from the wrong place. Since it is switched to eco mode, the electricity may not be coming to the opening module of the doors. If not from the battery, I didn't think of any other possibilities.
13.06.2020 23:04 # 6
ReCai
https://photos.app.goo.gl/ephnbevZPiqEACLM9http://photos.app.goo.gl/ephnbevZPiqEACLM9 If any intervention has been made to the vehicle's fuse panel recently, the position of a fuse in a different order than the others may have been changed. There is an insurance that is It must be in USER mode. It had happened to me before in my Citroen C3 brand / model vehicle. Your problem may be caused by the same situation.
15.06.2020 09:49 # 7
Kaiken
[QUOTE = ReCai] https://photos.app.goo.gl/ephnbevZPiqEACLM9http://photos.app.goo.gl/ephnbevZPiqEACLM9 If any intervention has been made to the vehicle's fuse panel recently, the position of a fuse located there, different from the others, may have been changed .There is a fuse with DEMO and USER modes. It must be in USER mode. It had happened to me before in my Citroen C3 brand / model vehicle. Your problem may be caused by the same situation. [/ QUOTE] valla teacher bsi brain etc. I do not want to deal with things, frankly, every master I take told me something different. I use it like this. I am afraid because there is no better answer. Thank you, I will try it.
