5. Gear and Reverse Shift problem
08.05.2020 21:11 # 1
umydn
When I started my car yesterday morning, I noticed that the reverse gear and 5th gear did not pass. My brother left in reverse gear while parking the night. I barely got out of the parking lot and came to work. The same problem persisted when returning home in the evening. When I went out at night, I used the vehicle at a high speed. Then I noticed that the gear got better. There is no problem right now. It passes easily and comfortably without sound. He wasn't making any sound before. Do you think there are any problems? Do I need to show it to the master?
08.05.2020 21:11 # 2
x571
if you do 1 or 3 and try to go back again when you don't shift into reverse. Another method is not to go back, take 1, move 1-2 cm, then pass back. If there is a problem despite trying these, then it is useful to take it to the mechanic.
08.05.2020 21:11 # 3
ismailkaya
When putting it in reverse, pretend to lift the clutch very little, but be careful, you will lift the spindle.
