5.cm or 3.5 cm closer in sports spiral
08.05.2020 18:22 # 1
natti
Friends with knowledge please I would be happy if you help TongueSmile natti 2014-03-10 18:40:12
08.05.2020 18:22 # 2
tlp
The type of cm specified in the springs is given in the type you can download the vehicle.
If you take 5cm, the vehicle will descend 5cm
If you take 3.5, it will descend 3.5cm
Priceless if you download 5cm + dish =)
08.05.2020 18:22 # 3
volkanC2
3.5 cm prints 3.5 cm, 5 cm prints 5 cm Wink 3.5 probably does not make much difference, there may be disappointment, we have to look at the experiences of friends who use 206 and sports springs. volkanc2 2014-03-10 18:48:05
08.05.2020 18:22 # 4
tlp
1.Picture with 5cm bow
2.Picture with 5cm bow + 2cm dish lowering
Picture 3 and 4 coil =)
tLp 2014-03-10 19:20:15
08.05.2020 18:22 # 5
volkanC2
Hullo Thumbs Up
08.05.2020 18:22 # 6
oguzhan29
maşallah coil super miş :)
08.05.2020 18:22 # 7
kursat3006
How long did you play with the back torsion?
08.05.2020 18:22 # 8
natti
I do not fully understand the back of the vehicle I bought in a very low tire, so there is not even a gap until you get a finger. LOL
08.05.2020 18:22 # 9
Adem Kurtuldu
[QUOTE = tlp] Picture 1 with 5cm bow
[/ QUOTE] Looking at brother 3 and 4, I think coil candir thought
08.05.2020 18:22 # 10
tlp
I spoke with the documents: D
the rest is up to you =))
08.05.2020 18:22 # 11
outlaw
WHAT DID YOU UNDERSTAND THIS DISH ???
08.05.2020 18:22 # 12
tlp
Publication block
Block surrounding the shock absorber
In the original shock absorber, the dish is independent, and in the shock absorber it coincides with a protrusion.
The bowl is boiled from the ledge and boiled in the shock absorber tube.
Care should be taken when lowering, if the tread is wide, it may rub against the tire
08.05.2020 18:22 # 13
outlaw
I USE A 5 YAY SPRING BETWEEN THE FENDER AND THE TIRE 1 FINGER BUT STILL NOT LOW ENOUGH.
MY TIRES 185/50/14 toyo proxes t1r DO I DROP IF I GET THIS DISH BELOW ..
OR THE LATEST REMOVE TO THE SUMMER 175/60/13 TIN WHEELS I WILL BECOME LIKE BASSIN ...
08.05.2020 18:22 # 14
tlp
I have 195/55/15, I did not rub it
I think you won't do it on your wheels 14
Base 185 meat 50 is in any case narrower and less wall thickness than I am
The important thing is not between the mudguard and the tire
The important thing is between the tire and the tire so there is enough share, you can download tLp 2014-03-11 11:50:15
08.05.2020 18:22 # 15
outlaw
Let's try OZAMAN WEEKEND ...
THANKS FOR INFORMATIONS ...
