4000 cycle shake hk.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206
08.05.2020 19:17 # 1
srdrgktp
Hello friends
2006 1.4 HDI 206 users occasionally hit 3rd gear 4th gear, sometimes 2nd gear, when cold or hot in gear, when the engine approaches from 3000 rpm to 4000 rpm, the engine shoots excessively. We asked why this was the reason that they solved the services to bring the masters to everyone, it is not always a problem, but they do not know why. I would be glad if you could help. Best regards.
08.05.2020 19:17 # 2
tilbe307
I had it in my gasoline car. the same problem officially did not seem to want to pass from 3000 to 4000, but when it goes over 4000, there is nothing. My problem is a piece called Crank speed sensor has changed. it wasn't a very expensive piece. I think it is between 60 and 80 TL.
08.05.2020 19:17 # 3
palet
Your fault may be caused by Crank pulley (Vibration damper). If there are problems such as stopping the vehicle at the first departure, late reaction to the accelerator, late acceleration, it may be time to replace the crank pulley. palette 2015-05-30 00:03:33
08.05.2020 19:17 # 4
ucanturk
I have the same problem. My vehicle is 2002 xt 1.6 lpg li. I am not very satisfied with its performance, the vehicle is not taken forward. all maintenance is ok, at 113 thousand km. ?
08.05.2020 19:17 # 5
palet
Controlled, simple to change. it is good to have it checked. The plastic hood folds back after removing the right wheel. the crankshaft pulley appears from there. The part that is already broken; Tire located between two metal parts. If it has started to crumble or if there are cracks, it will change.
If it did not change until 113,000, it is already time. Supply industry pulley 90 TL. the original is around 190 TL. Labor is 30-50 TL. They receive.
