40 lt LPG tank takes 25 lt? (307)
08.05.2020 16:02 # 1
kuantum
When I bought my 307, a 40lt LPG tank was installed on it, but it only takes 25 liters. I took it to the LPG master, the float said it was broken, but he told me to come later because it was not available. The man's attitudes seemed somewhat irrelevant, I was not sure. Is the diagnosis correct?
PS: so one day I was stuck. the gas is gone, the gas is gone and the gas is gone .. I didn't notice.
08.05.2020 16:02 # 2
scuderia
either the buoy is broken or there is air in it ...
08.05.2020 16:02 # 3
okan4037
First, it definitely takes off its air
08.05.2020 16:02 # 4
mon
How is the air inside these lpg tanks? Isn't it gas in the air after all? Why not go from the tank to the combustion room like LPG? Why does the air stay in the tank when the LPG runs out?
08.05.2020 16:02 # 5
okan4037
[QUOTE = mon] How is the air inside these lpg tanks, my mind is gone? Isn't it gas in the air after all? Why not go from the tank to the combustion room like LPG? Why does the air stay in the tank when the LPG runs out? [/ QUOTE]
When buying LPG, it is inadvertently pressurized so it is best to not take LPG in hot weather. It is best to take it at night or in the morning. LPG is not air. It is a liquid fuel.
08.05.2020 16:02 # 6
kuantum
Where can I get this aeration and how much money does it cost?
08.05.2020 16:02 # 7
taksicicocuk
Ask my friend the taxi driver, the buoy is broken, not to stay on the road or while the gas is getting filled, the tank slows down, then start shaking the car.
08.05.2020 16:02 # 8
It is the first time I hear that air is taken from the autogas tank. Who is doing this, where? How they do it. How much do they do?
[QUOTE = okan4037] [QUOTE = mon] How is the air inside these lpg tanks, my mind is gone? Isn't it gas in the air after all? Why not go from the tank to the combustion room like LPG? Why does the air stay in the tank when the LPG runs out? [/ QUOTE]
08.05.2020 16:02 # 9
okan4037
[QUOTE = Menderes] It is the first time I hear that air is taken from the autogas tank. Who is doing this, where? How they do it. How much do they do?
In 2009, I bought 307 atiker, I came from the military in May 2011 .. I went to LPG. It made a strange weather in 1.5 years ... I had a lot of air ... now I bought 307 cc. I was giving it to my father because I could not lift my head from work. ..
I just know that while it is getting air, there should be no fuel in the lpg tank, so you have to finish it completely ... I don't know if you can make your lpg service but it is really number 1 in my service business ... go tell me that there is air, they will not be completely unconscious from the tank.
08.05.2020 16:02 # 10
okan4037
There is no cost in terms of cost 5-10 pounds something, you can even have it checked in your setting;)
08.05.2020 16:02 # 11
boruc
My tank 32lt
It takes 22 lt or something max.
Is it normal or is it possible to be airy?
08.05.2020 16:02 # 12
maximusti
[QUOTE = boruc] My tank is 32lt
Is it normal or is it possible to be airy? [/ QUOTE]
When the tube is completely finished, press the spot in the middle of the place where you fill the tube with a hard iron rod, it discharges the empty air inside.
08.05.2020 16:02 # 13
Normally, there is no problem in me.
08.05.2020 16:02 # 14
x571
[QUOTE = maximusti] [QUOTE = boruc] My tank is 32lt
Let's not be crippled? while poking there
08.05.2020 16:02 # 15
Peugeot35
Finish the gas, make sure that there is no gas left, then slowly press the pointed thing to the point in the middle of the filling mouth and the air inside the tank is completely discharged. but it would be healthier not to ever play the vehicle to do this.
Your float may also be broken. If it is the same after receiving the air, your float is stuck. There is a cost of 100 TL if I am not wrong.
08.05.2020 16:02 # 16
maximusti
[QUOTE = x571]
Nothing happens if you don't try it with a cigarette in your mouth :)
