40,000 Maintenance
08.05.2020 19:55 # 1
maximusti
Hello friends,
We found 40,000
vehicle service started to give maintenance sign,
will be at the examination this week,
I called the peugeout service in Bayrampaşa in the service, he said that the Triger set should be changed since he was 5 years old, he said that I would spend around 750 TL for normal maintenance, 2300 TL in total with the Triger set. (especially if the spark plugs change) he said that the cost will be around 500 600 TL.
Do I need to change the timing set, and is there anyone you can suggest that I can have periodic maintenance on the European side of Istanbul?
thanks.
08.05.2020 19:55 # 2
maşallah hojam 2300 tl, whatever, maşallah in the service will make him play and play. I'm going to list it, teacher
1-timing set will change as the service says, because it is 5 years
2-cycle pump will be replaced
3-v belt will change
4-spark plugs will change
5-antifreeze will be renewed
Of course, I recommend you change it strictly as standard.
1-fat
2-oil filter
3-fuel filter
4-pollen filter
finally brake pads - brake fluid level - disk control - steering hydraulic level control etc. As an extra, undercarriage control and bellows are controlled. All of these should not exceed 1000 TL in a private service in the industry, hodja. Friends living in Istanbul will give expert advice. undercarriage etc. it will increase a little more.
sonerkyl 2016-08-08 16:30:28
08.05.2020 19:55 # 3
maximusti
[QUOTE = sonerkyl]. I'm going to list it, teacher
1-fat
2-oil filter
3-fuel filter
4-pollen filter
yes, teacher services unfortunately give very cold prices,
Since the warranty of the vehicle is over, I have to have it done in a private service.
There is no problem with my discs, I had it checked before, I just replaced the pads, it was about 1000 km.
08.05.2020 19:55 # 4
then if my teacher get together like this
1-timing set original around 150 TL
2-circulation pump around 100 TL original
3-spark plug original max 25-30 TL
4-antifreeze around 35-40 TL
5-oil total around 60-65 TL
6-pollen filter original 20 tl
7-oil filter original 15 TL
8-air filter with the original 15 TL
9-petrol filter 15 TL
10-v belt 20-25 rubles
prices will be around these average. only if something extra is added to the material, it will be between 500-700 TL. If you give 250-300 TL labor. It will not exceed 1000 TL.
prices will be around average. just a
08.05.2020 19:55 # 5
maximusti
[QUOTE = sonerkyl] so if we pack up my teacher
Thank you hojam,
It was a good guide.
08.05.2020 19:55 # 6
ziya alp
There were 206 2005 model 11 new modified truck 100 thousand has not changed before
08.05.2020 19:55 # 7
GokhaN
I know trigeri 10 years or 100 thousand km 5 years early
