! .4 I have my diesel overheated = (
08.05.2020 21:15 # 1
galesiz48
Hello friends, the return of the feast, 1.4, let's move, I stayed on the road, when the indicator came, I slowed down when it came to 110, the slower came to the ceiling, the heat stopped, the smoke came, we opened the hood, the water pipe going to the engine from the radiator was displaced: S 2 months ago, I had maintenance, bidet 9 cost 10 thousand thousand, what should I do? is it normal ?
08.05.2020 21:15 # 2
iso0625
Did you put the water in and then run it? My Astra vehicle had such a situation, the hose had come out, the water was empty, and when it came to the red line, I stopped. I put on the hose, put the water and continued. There was no problem but my vehicle was gasoline.
08.05.2020 21:15 # 3
ukayl
Get well soon, teacher, did you try to attach the hose afterwards, was there any problem in working?
08.05.2020 21:15 # 4
get past, replace the hoses, add the water of the car and check it a little bit. there is nothing to get into the engine right away as our friends say
