308hdi 130 km and above shaking problem
08.05.2020 21:15 # 1
Vakay
Hi guys, I just joined you, I have a 2008 model Peugeot 308 diesel vehicle. It has been a month since I bought the vehicle. I realized that the fifth gear is generally between 120 and 170 km, sometimes it is a shaking of the vehicle 4 times 5 times. If the problem coincides with it, it takes a lot of annoyance. After purchasing the vehicle, when I encountered this problem, the person I bought the vehicle said that he had just done the maintenance, but I had the maintenance again because it could be from the fuel filter. The fuel filter has also changed. Petrolophy is the other three shell. But did the same problem both of them?
08.05.2020 21:15 # 2
First of all, welcome to us. teacher there are several reasons for this.
1-tires
2-front plate bushings
3-damper bearing and wedges
4-front axle bearing and axles
I recommend you have these parts checked.
30.06.2020 13:32 # 3
Necdet
Probably Crank sensor malfunction Replace the crank sensor, I have the same problem. The crank sensor has been changed. The problem is solved ... There is a cost of around 300 TL including labor. Necdet2020-06-30 13:33:16
