307sw hdi fuel tracking diary ...
08.05.2020 18:44 # 1
albayman
2006 307sw 1.6 hdi my car went 890 km with 57 liters of diesel as a result of my first measurement in my mixed consumption. Generally, this result is good on very long and steep ramp roads? How do I use the duser already calmly? colonel financing 2015-04-13 11:53:45
08.05.2020 18:44 # 2
samet2461
It's a little bit too much. I have 307, 1.6, 110bg mixed, 4.5 liters. In fact, in my instant load, it shows 2.8 liters on the knee path.
the video i shot
08.05.2020 18:44 # 3
albayman
With cruise control, I fix the speed to 100, my instant consumption travels around 4.5 to 5. Sw is 200 kilos heavier, does it make a difference? What can I do to make this fall?
Note; diesel total excellium. colonel financing 2015-04-13 11:54:14
08.05.2020 18:44 # 4
samet2461
[QUOTE = colonel] I fix the speed to 100 with cruise control, my instant gear travels around 4.5 to 5. Sw 200 kilos heavier, the engine is 90. does it make all the difference? What can I do to make this fall?
Note; diesel total excellium. [/ QUOTE]
the fuel is the same as mine. I don't think he'll notice that much. It must be changed that I have passed over the air filter. when you had the maintenance done how many km.
08.05.2020 18:44 # 5
albayman
Just 2000 km ago, all maintenance including timing water pump alternator belt and bearing were performed. oil, air filters changed. I did not replace a single diesel filter. I will change it in the next maintenance with others.
I have never seen such values as 2.8 when I go with 100 on the long road. only when the 4th gear goes with 70, it becomes 3.5 lt instant consumption. Apart from that, the 5th gear does not go below 4 at 90-100 speeds. Does light friction of the brake discs cause this situation? There is a very slight friction that prevents it from being fresh.
fakaaat, the most important point is the consumption, the clumsy slope of mugla is descended 4 times. also the transfer is the same. those who know. I think this had an effect on fuel. my guess is in this direction.
08.05.2020 18:44 # 6
albayman
Muğla was enlightened and went home without traveling around the city and immediately returned.
vehicle 1500 kilos, 215nm torque
4 people and full of luggage. speed constant 110km on the long road. average speed 88km
200 km road took 9 liters of fuel. How about 4.5lt / 100km long way? the trip computer showed 4.2.
I don't tell you what you are burning in the city, what should I say, I think 8 liters.
and I understand that ramp fuel affects very much. The clumsy ramp of the mug exploits fuel ...
colonel financing 2015-04-13 11:54:50
08.05.2020 18:44 # 7
okan4037
I made 1000 km with a quarter tank. my way to antalya road go downhill curved road average speed was around 80 mercury. Out of the city, an average of 4- 4.5 can normally burn a bit when the leak is sw when it flies 130 lbs. but the most important is your accelerator response
08.05.2020 18:44 # 8
albayman
I filled the tank yesterday. I went 900km with 55 liters. so 6.1 liters per 100km. It requires a lot of patience in the city. Since the vehicle is heavy, stop in the city, take your speed, slow down again, stop, and the fuel increases a lot. out of town is fine. 4 liters are caught at a constant speed of 110.
08.05.2020 18:44 # 9
albayman
I completed the warehouse today. I caught an average of 5.5 liters. This time I used it with some caution in the city. I want to reduce it to 5 liters, but it requires extreme patience. neither he nor me.
1000 kilometers 243 rubles.
BUT THE ROAD COMPUTER 4.8 shows.
the average fuel I received in the pump is 5.5. what are the possible causes?
colonel financing 2014-09-24 16:20:36
08.05.2020 18:44 # 10
Can Oksuz
the trip computer's measurements are usually a bit down. I haven't heard of a full trip computer yet. This is not only valid for peugeot, all brands are like this. The measurement from the trip computer is not a very healthy measurement. you make the healthiest measurement by filling the full tank, resetting the km counter and finishing the tank.
08.05.2020 18:44 # 11
Efe-Pojo
[QUOTE = okan4037] I made 1000 km with a quarter tank. my way to antalya road go downhill curved road average speed was around 80 mercury. Out of the city, an average of 4- 4.5 can normally burn a bit when the leak is sw when it flies 130 lbs. but the most important is your accelerator response
[/ QUOTE] thank you, your car is like a plane, it goes 4000 km with a full tank. wow bea what are we getting on Shocked
08.05.2020 18:44 # 12
albayman
I looked at the fuel consumption in the user manual:
out of town: 4.5
urban: 6.3
mixed: 5.1 liters
08.05.2020 18:44 # 13
suppor
5.5 I think it's normal
08.05.2020 18:44 # 14
albayman
the result obtained by turning holiday traffic into an opportunity and using it calmly.
mixed consumption, including urban.
warehouse just over tomorrow
colonel financing 2014-10-07 20:06:31
08.05.2020 18:44 # 15
albayman
Since I last filled the warehouse, I have traveled 1092 km (1 month). today it received 54.5 liters of diesel. We enter the city 3 or 4 days a week, abundantly stop, park and travel. that is, mixed consumption.
the result fell to 5 liters at 100km. my goal was to drop 5. I don't think the 1.5 ton vehicle will burn less than this. I think the result is enough ...
Add: The road computer showed 4.3. there is 0.7 difference.
1092 km with 230 TL.
21 cents per kilometer
diesel liter 4.22tl
colonel financing 2014-10-24 19:15:42
08.05.2020 18:44 # 16
albayman
On 28.11.2014, I paid 240 liters for 58 liters of diesel. I have traveled 1080km.
5.37 liters of fuel consumption per 100km.
It means 22.22tl at 100km.
I used this title like my fuel consumption diary. I hope it won't be a problem ...
08.05.2020 18:44 # 17
albayman
On 24.12.2014
I paid 216tl per liter from 3.85 to 56 liter engine.
I have traveled 1143 km.
4.9 liter consumption per 100km
19 pounds of fuel at 100km.
Edit: Say goodbye LOL
colonel financing 2014-12-24 14:06:41
08.05.2020 18:44 # 18
okaNStarss
I think it is normal for my vehicle to go between 220-230 with 50 TL of fuel, so it takes 13 lt or something, but another master in my night sounds from the injectors for my vehicle and makes them look even more wasteful.
but there is no problem in the operation of the vehicle :)
08.05.2020 18:44 # 19
palet
My SWG with LPG vehicle, mixed spending is 40 LT. 385 - 400 klm with a tank LPG. is making way. There is a place where I bought LPG from 1.99, but generally the price is 2.25 TL in İzmir.
Average 2.10 TL. If I buy LPG from ..... 40 Lt. X 2,10 TL = 84 TL / 400 klm = 21 Kr.
There is not much difference between the diesel vehicle.
palette 2014-12-24 18:37:55
08.05.2020 18:44 # 20
albayman
[QUOTE = palette] My SW car with LPG, mixed spending is 40 LT. 385 - 400 klm with a tank LPG. is making way. There is a place where I bought LPG from 1.99, but generally the price is 2.25 TL in İzmir.
Let me write the numbers of the lpgli vehicle as someone who switched from the 2005 307sw lpgli diesel to the diesel:
When I was lpgnin 2.30 last year, when I was driving 20 km in the morning and 20 km in the morning every day, I wrote down all the gasoline and lpg amounts and their fees for almost 4-5 months.
At the end of my 6000 kilometers, it was 30 kurus per kilometer including gasoline and LPG.
because at first start, it runs with gasoline and passes to LPG at a certain temperature. In this cold start, the most consumption and gasoline (from 5 liters) therefore only lpg consumption can be deceiving.
Page : / 2
