307sw backplate lighting
08.05.2020 13:59 # 1
kamilgulcan
First of all, I congratulate everyone's feast of the sacrifice.
I want to turn on the back plate lighting of my 307 sw vehicle, the bulb on the right side is not working, I suppose it is not working ... but I did not find how to do it, I did not force it to break it ... I am waiting for an answer from friends who know the method ..
08.05.2020 13:59 # 2
It is either nailed or screwed. If you cannot see the screw, it is nailed. The nails are on the long side, the short one is not on the side. It is a plastic part that is removed with a thin screwdriver. It is not easily broken.
08.05.2020 13:59 # 3
hasimayaz
You will need to remove the Arga trunk liner. Our article for 206 will allow you to have an idea. The link is below;
hasimayaz 2008-12-07 18:27:52
08.05.2020 13:59 # 4
[QUOTE = hasimayaz]
You will need to remove the Arga trunk liner. Our article for 206 will give you an idea. The link is below;
ClapClapClapClapClapClapClapClapClapClapClapClapClapClapClapClapClapClapClapClap
08.05.2020 13:59 # 5
kamilgulcan
Thanks for the answers ... I hope it has nails, but it looks like I will remove the coating ...
08.05.2020 13:59 # 6
kamilgulcan
The pictorial diagram sent by my hasimayaz friend worked very well ... thank you very much ... first the upper part of the glass in the middle, then the right and left pillars are removed, then the main big coating is removed .. all this must be interlocked ... bulbs disassembled from inside and changed. .. meanwhile, push the star-shaped pins in the middle of the clips next to the lock mechanism by pulling them out.
08.05.2020 13:59 # 7
individual
hi hasimayaz
This is how the page structure in the servicebox in me came out.
I wonder if you distributed 10 square boxes on the page to the corners?
Smile
individual 2008-12-13 00:20:49
08.05.2020 13:59 # 8
hasimayaz
[QUOTE = individual] hello hasimayaz
Smile
Man vehicle Station Wagon. You got the screenshot from the Hatchback model.
