307SW ABS and ESP failure
08.05.2020 21:06 # 1
sahinsenturk
Hi
I couldn't find it exactly on the forum site, but my peugeot 307sw has been on for 1 week, ABS and ESP lights were on for a while went out and burned again. We put it in the computer and gave the right front wheel error. They told the electrician to show it.
1- Are electricians looking for such malfunctions because they will have to disassemble the wheel etc.
2- Where do you think the problem might be caused by, can it share the experiences that experienced this problem before?
3-Are there any repairmen you can recommend in and around the Anatolian side of Istanbul?
Thanks in advance.
08.05.2020 21:06 # 2
1-You can look at such malfunctions in electricians, but a peugeot master must find it as if he put it on the hand.
2-The problem may have several causes. abs sensor may be faulty. it may be dirty or scratched between the sensor. the front wheel bearing may be completing its life. Oxidation may occur in the abs sensor socket.
3- Our members from Istanbul will find advice on craftsmen.
08.05.2020 21:06 # 3
sahinsenturk
I went to peugeot special service today. they changed the cable problem was solved. workmanship + cable 300,00TL
08.05.2020 21:06 # 4
I'm glad your problem is solved, hodja. get past it.
