307sw 1.6 hdi glass removal problem |
| 08.05.2020 20:09 | # 1 |
When downloading the left driver window, it comes down with a single click like the other 3 windows. While I am left alone, I do not get up even if I hold it down, I have to do it all the time. I wonder why it could happen. There are a few things I have to ask. I have to do the maintenance every few thousand km. The mirrors are really small to me. Is there a bigger one, our changeover chances. the steering wheel came a little stiff where I have to look. Like every 307, there is a lacquer sound on the back. thanks everyone in advance good forums
| 08.05.2020 20:09 | # 2 |
ggitaristt |
Good luck .. welcome ![]() I think your glass button is broken. the glass control panel may need to be replaced .. (And when I reset the car, my windows were going up and down every inch. I don't remember now, but in this forum there was his solution, my windows were fixed, check this out before changing the keys.) In normal use, oil and filters change at 10000 km. That is normal car maintenance. But have the triger clutch pads or something checked if you don't know when they changed. Mirrors are perfectly normal, small but wide angle If you compare the steering wheel to the opelle or something, yes it is a little harder and gets harder as you accelerate. Good luck again .. 240nm strong traction, giant windshield, glass roof, and when you get used to the confidence on the road, you can not leave. If it is not a shame to ask, how much did you get and what is the hardware? (pack comfort premium vs?) |
| 08.05.2020 20:09 | # 3 |
sonerkyl |
We wish you to use the vehicle without accident and good luck. As our brother Mehmet said, coding will be done or the button is oxidized. Necessary subject is at the bottom. good forums http://forum.peugeotturkey.com/forum_posts.asp?tıd=22315
| 08.05.2020 20:09 | # 4 |
[QUOTE = ggitaristt] Good luck .. welcome ![]() I think your glass button is broken. the glass control panel may need to be replaced .. (And when I reset the car, my windows were going up and down every inch. I don't remember now, but in this forum there was his solution, my windows were fixed, check this out before changing the keys.) In normal use, oil and filters change at 10000 km. That is normal car maintenance. But have the triger clutch pads or something checked if you don't know when they changed. Mirrors are perfectly normal, small but wide angle If you compare the steering wheel to the opelle or something, yes it is a little harder and gets harder as you accelerate. Good luck again .. 240nm strong traction, giant windshield, glass roof, and when you get used to the confidence on the road, you can not leave. If it is not a shame to ask, how much did you get and what is the hardware? (pack comfort premium vs?) [/ QUOTE] Let me investigate the following topic a little. Thank you, I hope it will be good. I bought 1k km as soon as I bought it, 40 thousand times with the family, maşallah torque, comfort, comfort all in one, it was about 5 in the ideal long road. the person I received showed an invoice of 2 thousand lira. 3k ago, recirculating pads front pads replaced oil filter maintenance timing set. Let's say the price is a little high 115k org km single shifting right rear door sheet comfort package. Let's say 30 odd
| 08.05.2020 20:09 | # 5 |
[QUOTE = sonerkyl] We wish you good vehicle, no accident or trouble. As our brother Mehmet said, coding will be done or the button is oxidized. Necessary subject is at the bottom. good forums http://forum.peugeotturkey.com/forum_posts.asp?tıd=22315 [/ QUOTE] thanks i will try
| 08.05.2020 20:09 | # 6 |
I think the vehicle will work if you remove oxidized handle and clean the sections with oxidation. friends answered other questions already so I don't write |
| 08.05.2020 20:09 | # 7 |
[QUOTE = GökhaN] good luck because the 3 glass is working, I think there is oxidation, I think it will work if you remove the remote control arm and clean the parts with oxidation in the plug parts because the logic in those chips is simple friends answered other questions already so I don't write [/ QUOTE] Thank you, I will see
| 08.05.2020 20:09 | # 8 |
mAymIş oxidized. thanks, thanks
