307cc esp error
08.05.2020 17:57 # 1
scorpion_enis
Hello friends, I have a zavoli brand tube that I use for about 15000 km. he never took off in any problem. injectors have been changed recently, maintenance etc. was done. Then, as soon as the car was in the tube, it started to give an esp error, but the interesting thing is that it does not. I realized that. you know, while going in the cylinder, the gasoline indicator drops and gives the fuel low error. I fill the car with the tube, it gives the error as it moves in the tube, but if I take the 30 TL gasoline and come to the place where the float should be, that is when the low fuel error goes, I do not give the esp error. The tuber was surprised at this situation, 15000 km was not a problem as a result. Even if there was an error, it should be done in gasoline, straight logic. While the tube is being adjusted, there will be no gasoline. The vehicle will buy the bidet gasoline tomorrow. I was very stupid, my head stopped. Why do you think I've been living such a thing?
08.05.2020 17:57 # 2
error
an interesting event, in the utterances: D
08.05.2020 17:57 # 3
scorpion_enis
only one thing comes to mind I will try it. tomorrow I will buy 30 TL gasoline, when the buoy is where it should be, I will make the LPG setting and try it again as a bidet.
08.05.2020 17:57 # 4
scorpion_enis
More than 40 people who looked and didn't write anything.
08.05.2020 17:57 # 5
error
Interesting teacher, update between you and someone who knows the brain structure of peugeot will give you an idea
08.05.2020 17:57 # 6
Mustafa-almanya
Has the car ever been connected to a computer? Is only ESP burning, as well as ABS?
08.05.2020 17:57 # 7
scorpion_enis
There is no problem with the abs constantly connected, just esp is burning, a very interesting problem is still being dealt with. When it is resolved, I write here.
08.05.2020 17:57 # 8
scorpion_enis
problem solved lpg brain settings were reset when it was reset and made again :) (it has been done but it came to my mind to write that it was solved :)
