307cc before lpg after lpg
08.05.2020 16:41 # 1
Muhammet
Although I had the lpg installed recently, I made the measurements immediately and wanted to share it with you because my car was 2.0 engine and it was burning 55 & nbsp; penny fuel with 45 light presses when I used it calmly in the city. With lpg, when I bought it from the total, I loaded a bit to try the 28 cents lit performance, then I bought it from po and dropped the car up to 22 cents with a calm use.
08.05.2020 16:41 # 2
herry
22 kurus is free, you did well, good luck. i hope the lpg will not reduce the life of the engine
08.05.2020 16:41 # 3
elsoberano
the values are so great my 2.0 307 manual city couldn't drop down 27 cents in normal use
08.05.2020 16:41 # 4
Muhammet
I did not expect it to fall so far, but I am very happy, I traveled 100 km, I traveled 420 km before, I was going to sell 100 cars, 200-220, I hope I will sell the car .. I hope the engine life will not decrease
08.05.2020 16:41 # 5
okan4037
don't worry if your motor life won't be shortened if it is installed healthy .. only 2.0 auto 22 krş: S & nbsp; this value defeats me? What is the brand of LPG? & nbsp; I press light & nbsp; I burn 35 krs is the most economical & nbsp; I burn 30 krş. I have a problem with me except gasoline. There is a problem with your calculation. I couldn't solve it. If your consumption value is correct, I was so jealous:) & nbsp;
08.05.2020 16:41 # 6
tenten_52
By the way, which brand model LPG did you get, where how much money did you get?
08.05.2020 16:41 # 7
Cmoss06
Well, very good result
08.05.2020 16:41 # 8
Muhammet
I do not remember exactly but lpgn the brand's master told me that BRC has come from italy and Lavatoi of each part of the brand which is produced in Turkey and wear. Bagcilar gungoren in the auto industry, on the 16th block, it writes a huge LPG at the top. tomorrow when the vehicle leaves the coating, I look at the brand and write l got lpg to 1600. I went 220 km to 50 TL while measuring.
