306p stuck at the dock, changed problem continues
08.05.2020 21:01 # 1
Batu25
friends have changed the manager but the problem is still what else do you think
08.05.2020 21:01 # 2
Batu25
fixes when closed and opened
08.05.2020 21:01 # 3
talip206
The sender is original. If it is not original, there may be a problem. If you are sure of the sender, check the back mounting and cables.
There is only one place left to have a problem. The locking mechanism may be distressing in the gear lever section. But you say there is no problem when you switch the ignition off and on. Then the first option outweighs.
08.05.2020 21:01 # 4
Batu25
I bought the muur from 20 or 30 liras from Ankara hakan pejo.
08.05.2020 21:01 # 5
talip206
There is a peugeot citroen emblem on the original products. Does it sound like a click when you press the brake.
08.05.2020 21:01 # 6
Batu25
now I asked the original 60 sub-industry 20 I took it from the 20th, I think the 60's will solve my name.
08.05.2020 21:01 # 7
Batu25
I did not pay attention to the sound
08.05.2020 21:01 # 8
talip206
If the sender works, it makes clicks as it brakes and pulls. It would be good if I could return it if you talk to the particle before buying it. If it is not because of it, you cannot waste money. Hakan I was shopping with peugeot a few times, they were understanding people. I guess they can help.
The problem you mentioned is 90% related to the client, but as I said, there may be contactlessness in the sockets. In the meantime, parts prices have increased well. Last year, the original was around 30 TL.
talip206 2018-09-15 22:41:32
