3000 cycle problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206
08.05.2020 15:15 # 1
toprakk
Hi guys, hello to all of you. I have a problem. We couldn't solve it for 2 months. I made it look from the gas pump to the throat butterfly, we couldn't solve the problem. Problem ... my car is 2003 model 206 x-line. My vehicle does not exceed 3000 cycles. occasionally it sees 4000 revolutions but generally it enters the cutter at 3000 revolutions. my vehicle is gasoline. no tubes were attached. I'm waiting for your help.
08.05.2020 15:15 # 2
d3n1s
[QUOTE = Toprakk] Hi guys, hello to all of you. I have a problem. We couldn't solve it for 2 months. I made it look from the gas pump to the throat butterfly, we couldn't solve the problem. Problem ... my car is 2003 model 206 x-line. My vehicle does not exceed 3000 cycles. occasionally it sees 4000 revolutions but generally it enters the cutter at 3000 revolutions. my vehicle is gasoline. no tubes were attached. I am waiting for your help. [/ QUOTE]
is the vehicle automatic?
08.05.2020 15:15 # 3
tilbe307
I don't know if there is a crank speed sensor in the vehicle, but something similar happened to me. My vehicle was getting pregnant when it passed from 4000 to 5000 rpm. We replaced the crank speed sensor, no problem, man.
08.05.2020 15:15 # 4
yusuf206
Should not enter the cutter at 3000 rpm, I also cut at 7000 ....
08.05.2020 15:15 # 5
toprakk
My vehicle is not automatic. manual friends. I ask the crank dewir sensor to the master
08.05.2020 15:15 # 6
toprakk
What is the cost of the crank speed sensor?
08.05.2020 15:15 # 7
toprakk
You know? they said this forum is good. neither have cewap nor something
08.05.2020 15:15 # 8
307P
Could the injectors be clogged?
08.05.2020 15:15 # 9
toprakk
I took it again this day. They tied to the computer. coil malfunction werdi. we changed the coil again the same problem. There will be no software in the brain. Monday, I will print from Mersin and go to the island: @ warsa, you can write an estimated friends. our problem is up to date
08.05.2020 15:15 # 10
toprakk
we couldn't solve the problem in my husband
08.05.2020 15:15 # 11
tilbe307
crank speed sensor 50 - 60 tl workmanship 70 70 tlye handle it one try it very simple piece is installed in 5 minutes. my problems were that before replacing this sensor,
- sometimes hard work,
-misfire
Sometimes I don't stop when I waste my car
Jerky misfire at 4000 rpm
all of this is gone you have to take a good master to the car ... easy to come
08.05.2020 15:15 # 12
helot
[QUOTE = terrible] you know. they said this forum is good. neither have cewap nor something [/ QUOTE]
Anyone who said the crankshaft revolutions sensor, you said I would ask, but you didn't say if he asked. don't ask, tell him to change it.
08.05.2020 15:15 # 13
toprakk
Thanks friends. our serwis crank is not a sensor, he says: @ illa says the software will be thrown into the brain. he will go from Mersin to Adana. I could not find an opportunity because of the works. But if I am available tomorrow, I will go. I can install the crank dew sensor. let's see. I will write positive or negative here. By the way, there is no problem in the operation of my vehicle. it does not take one at a time. There's never been to hit the road. just the problem of excess fuel we do not exceed 3000 dewri. Let's look at the sensor.
08.05.2020 15:15 # 14
toprakk
Friends we tried the crank dewir sensor today. but the problem is the same. I'm going to the island tomorrow morning. the brainer taner warned. we met by wire. He said from the brain. I will print and go tomorrow
08.05.2020 15:15 # 15
kerim_car
look at the air flow meter. One can also control the gasoline pump pressure may be low.
08.05.2020 15:15 # 16
toprakk
We had a look at the Hawa flow meter, brother. In short, there is nothing we haven't tried. I took my vehicle to the island in the morning. what would they get from the appropriate brain code? I left the vehicle to Adana: ((
08.05.2020 15:15 # 17
metin
I had a friend who was using megane rs, riding a cutter at 3500 rpm. I don't know how it solved.
08.05.2020 15:15 # 18
toprakk
My car has been on the 3rd day on the island: there is no improvement. I don't understand what the job is
08.05.2020 15:15 # 19
toprakk
my friends problem is finally solved. As they say, bsi is out of the brain. I said that if I did not call yesterday on the 6th day, I will come and take it, and the work will not finish in 6 days. On this day, I set out in the morning and said that at 8 o'clock in the morning, the master called the car. anyway i went test or something. now my vehicle is entering the cutter at 6500. fell in fuel, we went gas, and wermeside improved. By the way, there may be those who wonder about the price. It took 400 tl: ((
08.05.2020 15:15 # 20
koliva
I wondered what he did to BSI that he got 400 TL?
Get well soon.
Koliva 2011-04-26 14:33:43
Page : / 2
