3. Shaking in gear
08.05.2020 21:13 # 1
Nine09
Hello to everyone,
The problem I had with my 2005 model 206 hdi vehicle is that I can not find the reason why it shakes between 2000 rpm and 2500 rpm when going routine in 3rd gear, can you help?
Thank you in advance.
08.05.2020 21:13 # 2
First of all, welcome to us. just doing this problem in 3 gears.
08.05.2020 21:13 # 3
x571
[QUOTE = Nine09] hello everyone,
If he is doing 3 and up gears, first of all we need to look at the ignition. then it is necessary to look at the gearbox. If it does only 3, 4-5 is OK, the problem may be in the gearbox.
08.05.2020 21:13 # 4
Nine09
Hello there,
It only does it in 3rd gear and it doesn't make me feel if I do the gear shift fast. 1-2-4-5. There is no problem in gears, there is no teak noise in the same speeds, only the 3rd gear shakes.
Nine09 2019-05-02 20:06:12
08.05.2020 21:13 # 5
then brother as if there is a problem with your 3-speed sequencer.
08.05.2020 21:13 # 6
Nine09
Thank you, I bought the pieces I will try in my boutique and this will be very expensive.
