3 problems in my car, not 1 ...
08.05.2020 17:30 # 1
Haydut06
Hello friends. My vehicle 2001 model 206 xt is now around 154800 km, the person I bought the vehicle has used so much contempt that I can say that I changed all parts of the vehicle 80% from the day I bought it. I don't think we have lowered an engine anyway ...
The problems I have now are the sounds coming from the clutch.If it is necessary to say 2 different sounds, if I pull my foot at the point of grip, it sounds like a "bird" sound, and then there are wires as if they were wandering together. strange wire sounds coming from it (due to km deb.print is about to come to the pad, but my master said he could manage it for 1 more year. He said it would not stop if it was finished after an experiment)
2. The problem is that I just came off the road and at the end of 250 km, when the vehicle is in idle, there is a strange noise coming from the engine and the entire instrument panel flashes very quickly when I press the throttle, but in the case of idle, the entire instrument panel flashes, I paid attention to the headlights of the vehicle. flashing in some way. As if there is a problem in the electrical component, the vehicle will stop at any time (I do not know if it may be caused by the battery)
3. The problem is that there is a strangeness for 1-2 days during the operation. When I press the starter, the engine is working as if it was going to move more than once. A sound came to my attention and got out of the vehicle. In case of an idle, there is a sound as if it was rubbing against another part.
I think this vehicle seems to cost me a lot after winter. How about you?
08.05.2020 17:30 # 2
qqyyxx
You posted the article you are talking about after the winter, I think find a good service as soon as possible and take the precaution before the current problems increase.
08.05.2020 17:30 # 3
serkan719
In case 1, you have to look at the clutch wire and look at the clutch ball.
2. The problem is, I do not know the sound of the card, whether it gives gas. But in the case of light, the charcoal of the charger is about to run out. The problem should be looked at the starter dynamo .. but I could not make sense of the friction sound. I say motor ears for shaking.
08.05.2020 17:30 # 4
Haydut06
I hope to meet me with a big expense .. I am thinking of taking it to the master tomorrow.
08.05.2020 17:30 # 5
serkan719
In which industry is your master?
08.05.2020 17:30 # 6
Haydut06
my master was not in the industry but in Dikmen, I went on the street of Sokullu. He looked at his feet. Nothing important. I'll leave the car tomorrow morning.
08.05.2020 17:30 # 7
Haydut06
I got rid of a figure like 180 TL :) For friends who have shortage ..
We solved the problem in the clutch by lubricating it. The master said that there is no need for ball or wire replacement. the room has been changed
and all my problems have been solved :)
08.05.2020 17:30 # 8
NightKiss
[QUOTE = serkan719] 1. In this case, you need to look at the clutch wire and look at the clutch ball.
2. The problem is, I do not know the sound of the card, whether it gives gas. But in the case of light, the charcoal of the charger is about to run out. The problem should be looked at the starter dynamo .. but I could not make sense of the friction sound. I say engine ears for shock.
Serkan agree with a friend. Measure the battery, measure the charger, see how much it is charging.
The friction sound is probably from the belts.
Get well
