3 lines display
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:51 # 1
206x-line
Vehicle 2004 If I wear a 3-line display, what do I need to do? If I take the screen for it to be active, can I wear it?
08.05.2020 18:51 # 2
P206HDi
My 2006 vehicle had worked when plugged in. To change the data, you need to either change the wiper arm or remove the plastic piece at the end and do some work. Apart from these, if there is a temperature sensor under the right mirror and you want to see the temperature on the screen, you have to pull the cables and activate it.
08.05.2020 18:51 # 3
P206HDi
http://forum.peugeotturkey.com/forum_posts.asp?tıd=16691
There is a good expression here.
08.05.2020 18:51 # 4
206x-line
Then we just need to buy it and see if we can
08.05.2020 18:51 # 5
206x-line
Do you have 3 lines of screen selling?
08.05.2020 18:51 # 6
Alicilik
See the second hand title on the site there sells Ozgur.
In 2006 and below, you have to activate the on-screen computer with the help of pp2000. Otherwise, you cannot see the parameters.
