3 line information display problem - short circuit -
08.05.2020 19:49 # 1
dagdelen34
Selamun aleykum
I was struggling when the socket of the information screen was plugged, the information screen was short-circuited as a result of the aluminum foil contact, km indicator, gas and temperature gauge, 4-flasher etc parts did not work, you know, I checked the fuses, no problem, I removed the information screen, everything was fixed, do you have the information screen short One way I can go through the circuit
08.05.2020 19:49 # 2
I hope my teacher has passed and I hope it was not a problem. A good check is required if the chassis may have formed in the socket. or you have to plug in another screen and try.
08.05.2020 19:49 # 3
dagdelen34
The correct output of Sonerkyl is correct, there is a chassis in the socket, probably another screen is working, all the errors disappear.
08.05.2020 19:49 # 4
I have to disassemble the screen and look at it, if my teacher has melted, there is nothing to do without seeing it.
08.05.2020 19:49 # 5
red 206
you can clean the socket (screen) with the help of a pin.
08.05.2020 19:49 # 6
dagdelen34
The inside of the socket looks clean, I gave it to a friend who understands electricity.
