3 fault lights
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 21:17 # 1
muallim45
Hello friends
I am a 2013 model 3008 user. My vehicle has been with me for a few months. recently lit three fault lights on the long road (540km). On the way, the car started to crow. I turned off the ignition and got off the vehicle. I locked. 5 minutes later I ran it missing. happened 3 times on the road. The lights went out in the same way in all of them. Burning lights in triangle, exclamation esp and electric parking brake. the vehicle continues to work, though. I would appreciate if anyone knows why.
08.05.2020 21:17 # 2
muallim45
Someone who was not ESP but ASR light.
28.02.2024 10:28 # 3
radyotolga
I'm going to revive the old entry but... I have the same problem. From what I've seen on foreign forums, the problem may be caused by the brake switch. I haven't had a chance to get it checked yet, but for me, it also gives ABS ESP and auto handbrake errors and disables traction control. But the automatic handbrake continues to work.
29.07.2024 14:47 # 4
Nesocy
Don't look anywhere else than the brake switch socket. The reason is that when you press the brakes, the pins of the socket loosen over time, causing a problem and a problem. The solution is to either buy a new socket and replace it, or like me, put a single copper cable between the pins of the socket and tighten it, which will take a year before it starts working.
