3 Connecting Amplifiers?
08.05.2020 18:28 # 1
Piyanist89
sa friends I want to connect 3 amps to my vehicle. the reason for this is let me explain
I have 2 sets of pioneer 6995s hoporlorum.
I have jbl mid team in 1 team.
There is 1 set of tss20.
The problem is that pioneer 6995s reporters are worth 100 rms. right column 100 rms left column 100 rms total 1 set makes 200 rms. Since there are 2 sets in me, it makes 400 rms in total.
Now the plan is on my mind.
2 4-channel stereo amplifiers
1 mono amplifier
If I connect 1 4-channel stereo amplifier pioneer 6995s, I need to connect 4 channels for the columns to work in 4 ohms, I think there is a serial connection in the name.
When 4 channels are full. There is no space for mid and tss20s. This requires a 4-channel stereo amplifier.
1 4-channel amplifier. If I enter 1 set of 6995s in a single channel, I connect it in 2 ohms. and it requires 200 rms of power in 1 set. If there is an amp producing 200 rms power in 2 ohms, it is expensive. If I get an amplifier that gives 150 rms per channel in 2 ohms, it will not be enough. I think I will not get an efficient sound again.
If I connect 3 amps, can I connect my pioneer 3650ui model with 2 rca outputs to these 2 rca outputs?
I think 3 separate deck cables and power cables will be required for the 3 amps.
will the battery of the car be able to run 60 amps 3 amps?
will it be necessary for a captainer? As far as I know exactly what the capacitor is doing, it charges the battery while the car is running while charging the battery. Is it the right pulling power from the capacitor when we listen in stop?
I think it was a bit complicated :)
Meanwhile, I read in another place that 1 team of speakers gave 100 rms on the right and 100 rms on the left and totaled 200 rms. I knew it would be right 50 left 50 and 1 team add 100 rms.
08.05.2020 18:28 # 2
Alicilik
My volume needs to sit with you and talk for a long time.
There are wrong information and complicated situations that are solved, but a powerful and high-quality amp serves your job. we finished with more speakers and less amps than that.
08.05.2020 18:28 # 3
Piyanist89
Based on the information I gathered on the internet, I created something in my head, the sound system event does not end well without bottom :)
08.05.2020 18:28 # 4
barishrocker
My circumcision shunt is like that, but there is no need :) You can connect ovals to 2 channels, stomachs to 2 channels, treble to tape output as a powerful 4 channel amphitheater 2ohm. If you had 3 RCA tapes, you would do what you said. You would not be loaded on the battery. Because the battery may not be enough.
It could also be: ovals to the tape output, 4 channel amphitheater mid and treble, monoya sub ...
08.05.2020 18:28 # 5
Piyanist89
The ovals are connected to 2 channels. It works in 2 ohms. If you connect me 4 ohms, they would say better quality sound, I turned to connect 4 ohms from it. now anfi is already edison 505 a
the link is like this
2 sets of ovals connected to 2 channels
1 set midler connected to 1 channel
1 set of treble beams connected to 1 channel
4 channels full now + pioneer 30 cm bass connected to sub output
Ozmn will be edison 505 instead of a beautiful amphitheater. Mono amphitheater in bass.
The amphitheater plays even though I don't load that much, but the sound distorts in the 50s. I think he's doing it from the amp.
08.05.2020 18:28 # 6
Piyanist89
[QUOTE = 307bursa] The information you have received or received is very accurate.
I have 4 of your ovals, 2 sets of them, their rms power is maximum 60 trucks, you can feed them very healthy with a single and beautiful streo amp.
You also have 1 set of ovals and 1 set of mids in the same way.
Also, when you connect 1 bass and 1 mono amp to this facility, it will not be eaten.
pioneer inflated the value of 100 rms written on the ovals.
By the way, I have 2 sets of ovals.
