2nd heat sensor to the radiator?
08.05.2020 21:05 # 1
lilokan
My master looked at the radiator for another thing, and meanwhile, the temperature was sometimes approaching 100, and he said that a second sender could be followed. He said the fan opens in 87 or 90. He says the heat is no problem. Does anyone know about this? Should we get it done as he says?
08.05.2020 21:05 # 2
frankly, I've never heard of it, hodja. Maybe it will be done with a few electrical operation, but it is obvious that I have never heard of it.
08.05.2020 21:05 # 3
lilokan
[QUOTE = sonerkyl] frankly I've never heard of it, hodja. Maybe it will be done with a few electrical operation, but it is obvious that I have never heard of it. [/ QUOTE] we need to investigate a little more then let's not get a job for our teacher :))
08.05.2020 21:05 # 4
hozer33
my vehicle had a temperature problem, they made such a recommendation, it was a solution to some extent, they do not have any problem.
08.05.2020 21:05 # 5
lilokan
[QUOTE = hozer33] There was a problem with the temperature in my vehicle, they made such a recommendation, if there was a solution, they do not have any problem.
[/ QUOTE] Are my teachers or brain or electrical stuff tumbling after the tact? Is it risky or simple?
08.05.2020 21:05 # 6
hozer33
I made it to a master in Mersin, he said he was making a connection to the brain.
08.05.2020 21:05 # 7
x571
[QUOTE = lilokan] My master looked at the radiator that I went to for something else and meant that the temperature is sometimes close to 100, and said that a second sensor could be followed to this radiator. He said the fan opens in 87 or 90. He says the heat is no problem. Does anyone know about this? Should we have it done as it says? [/ QUOTE]
Well, the second tier doesn't open like 95 anyway. Do not go into such stupid things, you can not collect the car. The right thing to do is to open the second stage fan to control it. I know the easiest way is to control it with air conditioning.
08.05.2020 21:05 # 8
lilokan
[QUOTE = x571]
You are right, teacher, we cannot find the right master, but the problem is actually
