206XR TIRE RECOMMENDATION
08.05.2020 19:10 # 1
umitgun
First of all, if I opened the right topic to everyone, do not look at my car, I'm new in the new forum and you're the first Smile My vehicle (2002) is 206 XR 1,4 Gasoline model. Is it suitable for 195-50-15 tires in my vehicle, does it make a difference in fuel or will there be low traction?
08.05.2020 19:10 # 2
mtok61
besides the original traction fuel traction, it can cause mechanical problems in the car.
08.05.2020 19:10 # 3
madblueblacksea
It has a diameter of 7mm smaller than the original (- 1.23%), but it is likely to experience stiffness in the steering wheel due to the large base, and a decrease in comfort not in the 206s because it is a narrow cheek.
08.05.2020 19:10 # 4
umitgun
Well, can you suggest a tire that will not rub more than the original one?
08.05.2020 19:10 # 5
madblueblacksea
What is the rim size?
08.05.2020 19:10 # 6
samet206
The only thing I can recommend is the original 175/65/14.If you are original in the spring, you will continue on the road with 65 sidewalls comfort, 175 base and 1.4 engine fuel, without any trouble. hardens, fuel is not felt at first, but increases, if there is a small decrease in traction, contractions occur in the vehicle. so it will definitely be necessary to press the vehicle. My recommendation on 15 rims is 185/55/15 tires. This is the closest measure to 175/65/14 and also the fuel rates are almost the same in the calculations. If you want to use 15 rims as the number of revolutions in 206, this is my recommendation for tire size.
08.05.2020 19:10 # 7
madblueblacksea
I use 185/65/14 and with the grip on the road increased by around 0.8L in fuel. Can I wear it 175/65/14? My nickname Smile
