206xr immobilizer chip helpmmm
08.05.2020 15:30 # 1
furkanbaki
my friends vehicle 206xr immobilizer chip is defective just need to find the chip i'm in the district of mersin this soon i wonder if i can find the chip there is a master who can handle it with the program, i know anybody can know
08.05.2020 15:30 # 2
how did that jeep fail ??? I also have no idea where it can be found
08.05.2020 15:30 # 3
furkanbaki
I need to find a tiny black chip in the key from it, the masters will introduce it with the computer but I couldn't find it
08.05.2020 15:30 # 4
In fact, his name is tranponder. I don't know what is going on well, what I don't understand is how is it broken?
Until today, I have never heard that it is broken ...
08.05.2020 15:30 # 5
Kemanyak
Water contact may be like that. As far as I know, you can get it only if you apply to the authorized service with the information of the vehicle. They give it with a new key. They introduce them to the vehicle, etc. Address authorized service.
08.05.2020 15:30 # 6
Kemanyak
Have you ever tried cleaning the chip with WD 40? I saved many electronic devices with this product :-) Try it, you will not lose anything. There may be a problem due to oxidation.
08.05.2020 15:30 # 7
In the same way, you can use it in contact spray.
08.05.2020 15:30 # 8
106_arts
that chip is not in the style to be cleaned, friends, I looked at it, I got the key of my keymaker, chip 60 lira
08.05.2020 15:30 # 9
furkanbaki
brother, too many numbers, but let me see a master who will code, but if I make sure you can get back I will return to you
08.05.2020 15:30 # 10
106_arts
I used the normal key for 100 lira with chip, I switched to 206
08.05.2020 15:30 # 11
furkanbaki
Oh brother, this is the deprivation area.
08.05.2020 15:30 # 12
106_arts
I am here until Wednesday, I will not be able to send it to you, ask the master
08.05.2020 15:30 # 13
furkanbaki
okay in my master they will know that you sent my standard
08.05.2020 15:30 # 14
There are two keys on that black little key, I press it does not react .. Kahkaha But there is a switch with switch, when you start the car, open the doors, activate the alarm. Sırıtma I don't know what the key with two keys on the other is. In that case, the key you call immobilizer is that key? if it is key, mine is defective then so?
08.05.2020 15:30 # 15
furkanbaki
Exactly my square :)
08.05.2020 15:30 # 16
[QUOTE = You by_]
ah be brother yaa :)) o 2 keys is the original key. The key you use is not original. o the key to the alarm. What you call immobilizer happens on the top of the vehicle, not inside the key. but there is a little jeep inside the key case. the other name is transponder. He is a secret secret. when the key is inserted into the ignition, when this syllabary complies with the sifre, it is allowed to fire and the vehicle will start ...
the cecol 2011-05-30 14:17:53
08.05.2020 15:30 # 17
[QUOTE = cecol of] [QUOTE = You by_]
My first job will be to start the vehicle with that key when I go home. Let's see if it works .. Sırıtma Well, if you don't have that jeep, you said the car won't work. How about the switchblade switch?
08.05.2020 15:30 # 18
Is there a furkanbaki casco?
08.05.2020 15:30 # 19
I tried it, it didn't work .. it just opens the doors. opens the fuel filler lid .... enters the contact but turns neither right nor left..I did not understand it, I got it from here..I wondered that there are 2 keys on the top, I opened the inside and there is a battery inside. Sırıtma I mean, I could not see the chip mip .. I wonder if they removed it and put my other key on it?
I did not have the courage to remove the other key .. Embarrassed
you by_ 2011-05-31 09:28:29
08.05.2020 15:30 # 20
actual
Page : / 2
