206hdi does not exceed 3000 cycles |
| 08.05.2020 13:56 | # 1 |
| 08.05.2020 13:56 | # 2 |
km how many times now with great chances, the prick injections from the fuel are blocked If I think I think it would be a problem with carbon clean are you in Istanbul |
| 08.05.2020 13:56 | # 3 |
IsmailAtes |
There is a problem with the deran brother's surplus, or there is a problem with the turbo.
| 08.05.2020 13:56 | # 4 |
MirakGTI |
I had the same problem, as Deran said, injections have something. |
| 08.05.2020 13:56 | # 5 |
sinan-s |
Injectors are dirty. Deran abi 206 HDi specialist. All they say is true ...
| 08.05.2020 13:56 | # 6 |
There are many possibilities The injector may be clogged. The Institution May Have Bound. Can Be Air Flow Meter. Sometimes injectors are not recovered with carbon clean, they need to be removed and cleaned. If the carpex injector cleaner at 3 boxes does not fit into the tank, get the service now.
| 08.05.2020 13:56 | # 7 |
Try carbon clear you did not look anyway the car should not be neglected, you should always enjoy it FOREVER PEUGEOT
| 28.08.2020 00:32 | # 8 |
Can you help me my brother? I have the same problem, but the turbo was renewed, everything is 0. My only problem is not exceeding 3 thousand revolutions.
